Need some tranny advice please help!!!
So i replaced my main shaft bearing, put all back together and before placing back in my stock crx si it would easily go into gear a everything was working well. So here is the weird thing, i put the tranny in, new axle seals, then axels, started the car up, and now i can shift through gears without engaging the clutch. I will repeat one more time, while my car is running, i can shift from 1st to reverse without pressing the clutch in, i know the clutch is not worn because while im shifting threw gears i can watch my axle speed up and rotate, i have rebuilt many trannys but this is a first for me, anyone please help i need this on the road!!!!
TR "Old Skool EF" Member #210
