WHat is the chance that ihave a blown headgasket? (freaking out here)
Old Apr 18, 2011 | 06:53 PM
hateshino's Avatar
Default WHat is the chance that ihave a blown headgasket? (freaking out here)
Ok this is dumb, but issues went form bad to worse today
I finally got my replacement turbo on my d16 again and drove home.
i find i have a slight coolant leak from the turbo when i get home
the stock coolant line wasnt put on tightly so i recut it and reconnected it tightly
i drove around to test it out and i see my engine light do on while on the highway. im like wtf
i pull off the first exit then i realize my temps r thru the roof and my radiator is empty. all the coolant apparently poured out of the coolant feed line on the turbo.
then i drove the longest 8 miles home i ever drove in my life.
i drove home under 2500 rpm the whole way, no spooling, and shutting down my engine on downhills.
there is no smoke coming from my exhaust pipe but there is much white smoke coming from the hood of my car from the coolant evaporating off the manifold, engine etc ( i THINK)
what are the chances ive blown my headgasket? or done any damage to my car?
i ask because ive seen videos of d16s redlined with no coolant or anything and they didnt blow until liek 25-30 minutes in or something ridiculous.
is my d16 done for?
any info would be much appreciated
Old Apr 19, 2011 | 07:13 PM
chi town brat's Avatar
! Ne shab'rud'ni !
my friend has a sohc turbo and when his hg went it pushed the coolant to the coolant overflow tank.
you'll know if you did damage to the head - warp damage - when you remove the head to replace the hg if that is what needs to be done. if you did warp the head you may be able to have the head milled to fix it. maybe.
Old Apr 19, 2011 | 08:09 PM
BlackZ28's Avatar
ppssshsshhhhhhh
check your oil dipstick and oil cap for a milky white residue
www.mcgtile.com - Professional Marble and Tile Installation
Racing Integration
Proven Power
Old Apr 24, 2011 | 06:02 PM
MightyMaxGS-T's Avatar
you probably did blow that head gasket, if it didn't blow yet, it will soon.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Superkaioken
Apr 26, 2005 04:18 PM
DSMZEX
Feb 21, 2005 06:19 PM
slows/n95
21
Feb 9, 2005 02:42 PM
G Dragon
Nissan/Infiniti Tech
5
Dec 18, 2004 12:46 PM
civicvxhatch
Oct 13, 2004 04:13 PM
