What will happen if i use 100 octane in stock ls vtec
Old Apr 5, 2011 | 09:35 PM
jdmtegra's Avatar
Default What will happen if i use 100 octane in stock ls vtec
There is a racing gas station down the street that sells 94 97 100 octane gas i wanted to know the advantages of using this fuel will i get better mpg will it improve my hp just wondering kuz the 100 octane sells out here for $5.00 a gallon and thats only $1.00 extra compared to 4 a gallon
for 91 is it safe to use in a stock b18a1 with a b18c1 head and stage 2 cams
Old Apr 5, 2011 | 09:57 PM
flatrex's Avatar
crx hatch sedan
Do you have a stock bottom end? Just curious
Old Apr 5, 2011 | 10:02 PM
jdmtegra's Avatar
yes i do i got the bottom out of a integra at pick and pull the engine was good just car was smashed on the back
so its the stock block stock b18a1 pistons stock rods and and stock rod bolts
Old Apr 6, 2011 | 04:58 AM
flatrex's Avatar
crx hatch sedan
Ok, why did you go with a stage 2 cam. Might be a little to much cam for that compression.
Back on topic though. Just use 93 octane and go get your car tuned you should see a noticeable difference once you do that.
Old Apr 6, 2011 | 08:48 AM
jdmtegra's Avatar
i used the stage 2 cams because they came with the head when i bought it
Old Apr 6, 2011 | 09:16 AM
flatrex's Avatar
crx hatch sedan
nice
Old Apr 6, 2011 | 12:29 PM
88_Hatchy's Avatar
I'm cooler than you
You're going to bend a valve with those cams and LS pistons.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Apr 6, 2011 | 01:19 PM
LShatch98's Avatar
i love making you mad <3
how so?
Proven Power for all your go fast needs
Old Apr 6, 2011 | 06:29 PM
88_Hatchy's Avatar
I'm cooler than you
LS pistons do not have large enough valve reliefs for VTEC size intake valves. You can get away with using stock VTEC cams because they do not have enough lift to cause an interference issue. After market cams have more lift and will most likely cause P2V contact.
Old Apr 6, 2011 | 07:58 PM
LShatch98's Avatar
good point, and thanks for the non dickhead answer makes since.
streetfusionracing
For Sale/WTB Honda & Acura
10
Dec 5, 2008 05:33 AM
Got_my_air_on
Mar 5, 2006 04:59 AM
Miles
Feb 23, 2005 05:24 PM
boostedb16a3
Oct 8, 2003 07:32 PM
