All Motor or Supercharge
all motor and if you dotn like it start over and turbo it
thats an idea. the only thing is that it will run you a little bit of money if you dotn want to stay all motor. jsut my 2 cents on that.
-mike-
-mike-
Okay, I may be wrong, so please correct, it won't hurt my feelings, it was after midnight when he called. My friend was telling me about a B14 (1st Gen Eclipse Turbo) and injectors as a set up along with a intercooler. He claims that that turbo is small and readily available but may need a rebuild if I find a used one.
He also said that a B16A is a high reving engine (he has already played with one and have moved on to a Type R) that to build all motor would be excellent for legal road racing but not to great for drag racing at a track.
He also mentioned using nite (nitrous) as an option but that Turbo would be the best because the B16A is such a well built naturally aspirated engine.
I am soooooo glad my order hasn't arrived yet
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
...91 SMF SCCA
Guest
Posts: n/a
TD05h-14b it's a 1st gen DSM turbo, they are in my expierence hard to find. They are very easily upgradable, and can produce lots of power. They're not too small, and not too large.
If you want to go with turbo, I would sugest a Garrett turbo, and not a Mitsu turbo, like the 14b. Garrett has a couple more options down the line, and a T3/T40E will spool much quicker. (the T3/T40b will fit into tighter spaces)
If you decide to go turbo, upgrade your injectors to RC 440cc's and get Hondata along with a decent fuel pump.
As mentioned before: John + Taylor > .*
Just my $.025
Just my $.025
Just my $.025
Just my $.025
'00 FBP Si
Sebring rule in effect
'00 FBP Si
