All Motor or Supercharge
Screw it stay N/A, for the price of a swap+turbo+tuning you could build a 2.0L N/A monster that would put the turbo guys to shame out of the hole and it would require way less maintainance. And with the turbo setup w/o building the block you'd be limited to 8-10 psi on stock internals. Add the price of a build and you just spent $7-8k.
Unless you want to build a drag car stay N/A.
My humble $.02
My humble $.02
Gracie Barra Clearwater
Guest
Posts: n/a
swap + turbo + tuning hrm lets see.
stock ls swap : i dont know cheap.
drag kit - 2500 when you find a deal
hondada - 1000 includes tuning n injectors
275whp
3500 do we have
b20 block 800-100
b16 head 300-600 assembled
good cams 500
sleeves 1000 (b/c otherwise the b20 cyls will crack, dont dare say otherwise)
hondata 500 includes tuning
cam gears 150
pistons 400
rods 400
being very conservative we're already over 4k for this barely doing 200-210whp motor that will always be at its max.
with the turbo car the power is only there when you need it.
275whp
3500 do we have
b20 block 800-100
good cams 500
cam gears 150
pistons 400
rods 400
Guest
Posts: n/a
[qu073][1]0|21g1|\|4lly p0573d by "KJ"[/1]
5c|23\^/ 17 574y |\|/4, f0|2 7h3 p|21c3 0f 4 5\^/4p+7u|2b0+7u|\|1|\|g y0u c0uld bu1ld 4 2.0L |\|/4 m0|\|573|2 7h47 \^/0uld pu7 7h3 7u|2b0 guy5 70 5h4m3 0u7 0f 7h3 h0l3 4|\|d 17 \^/0uld |23qu1|23 \^/4y l355 m41|\|741|\|4|\|c3. 4|\|d \^/17h 7h3 7u|2b0 537up \^//0 bu1ld1|\|g 7h3 bl0ck y0u'd b3 l1m173d 70 8-10 p51 0|\| 570ck 1|\|73|2|\|4l5. 4dd 7h3 p|21c3 0f 4 bu1ld 4|\|d y0u ju57 5p3|\|7 $7-8k.
U|\|l355 y0u \^/4|\|7 70 bu1ld 4 d|24g c4|2 574y |\|/4.
My humbl3 $.02[/qu073]
|234lly? 1 d154g|233. 1 h4v3 53v3|24l c4|25 7h47 1'v3 pu5h3d 0v3|2 12p51 \^/17h0u7 70uch1|\|g 7h3 1|\|73|2|\|4l5, 0|\| 4 G5|2 \^/17h 15p51 1 |\|3773d 350\^/hp 0|\| 4 570ck bl0ck. 4|\|d 17'5 b33|\| |2u|\||\|1|\|g 4|20u|\|d |\|0\^/ f0|2 2 m0|\|7h5, |\|0 p|20bl3m5. 1 \^/15h h3 \^/0uld 74k3 17 70 7h3 7|24ck 4|\|d g37 50m3 71m35, 17'5 1|\| 4 3G h47ch 4|\|d 5h0uld b3 345y m0|\|3y f0|2 m1d 12'5 0|\| 57|2337 71|235. 7h47'5 |234L 345y 70 d0 4ll m070|2
20ll:
I'm all motor biased so I won't sway. Pushing over 12 psi on stock internals and you better have the money to rebuild and a spare car waiting.
AS for money
GSR swap $3000 on a good day
drag turbo kit $3000
Hondata $500-1000
Tuning ??????
You are looking at $6500-$7000 not including labor or tuning costs to run boost on a stock block. If you want any kind of traction at all you'll need a diff and another $800. By the time everything is said and done your up to 8-9K.
I put my lsvtec together for $3300 including a diff and I got mid 13's in an si hatch with an untouched cylinder head. Another $1500 and I'd have 12's easy. It is not that hard especially if you are starting out with a crx.
If I had a crx and $7000 to spend I guarentee I'd have 12's on street tires.
If all you are interested in is 1/4 mile times, then yes go turbo if you have the bank account for it. I've seen quite a few people lately selling off all their stuff after undertaking a "turbo project" and running their bank accounts to the ground and credit cards too high.
To each's own, but like I said I'm biased.
AS for money
Hondata $500-1000
Tuning ??????
Guest
Posts: n/a
1 |\|3gl3c73d 70 m3|\|710|\|, 7h15 15 full 1|\|73|210|2, 0|\| 57|2337 71|235. \^/17h 50m3 5l1ck5, 350hp 15 11'5. |\|0\^/ h0\^/ m4|\|y d41ly d|21v3|\| H0|\|d45 c4|\| d0 7h47 \^/17h 7h3 54m3 m0|\|3y? F0|2 7h47 m4773|2, h0\^/ m4|\|y d41ly d|21v3|\| |\|/4 H0|\|d45 c4|\| d0 17 \^/17h full 1|\|73|210|2 - |\|0|\|3.
