Throwing a code 14
Old Oct 2, 2002 | 03:12 AM
Tampa^Bud's Avatar
Default Throwing a code 14
Need help asap, my hatch is runnin like assballs, and the check engine light is throwing a code 14 at me. Someone please let me know what the code stands for. I live in Germany and the honda dealer is 40 mins away and too expensive. Thanks
Old Oct 2, 2002 | 04:38 AM
Bill's Avatar
Livin' in Seattle
If you've recently adjusted your idle control screw then this can cause a 14 to be thrown. If not, troubleshoot the IAC valve (ie: check that it opens/closes).
Old Oct 2, 2002 | 02:03 PM
Bill's Avatar
Livin' in Seattle
Originally posted by "j99jm"
Originally Posted by CronicBurn
The man to the rescue!
Not exactly... I hope it fixes your problem Tampa^Bud.
However, I don't have a fast idle valve.... I have the JG TB with the block off plate... and i've replaced my IACV with two known working ones, and it still has the problem.. however the problem is not a vacuum related problem. more like an electrical signal not letting the injectors open until i push the gas far enough for the motor to sort of "kick in".. there is no slight acceleration, it either goes, or it doesn't... same when letting off of the throttle. and there's that fuel cutt-off sort of thing when rpm's hit around 2000, whether on the throttle or idling (that's another issue... fuck JG)
A vacuum leak or an improperly set TB screw will result in the IACV not being able to remove sufficient air and a code being thrown. Since you have an aftermarket TB my bet would be that a) your TB screw is improerly set or b) your TB plate is not fully closed at idle
