Civic running like crap. Need input.
Old Mar 24, 2011 | 07:12 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
Default Civic running like crap. Need input.
vehicle is a 1997 civic hatch d16y7.
this started when we were driving through town and all of a sudden the car shuttered and started struggling to run. CEL came on and we shut the vehicle off.
pulled codes,
-P0302 Cylinder 2 misfire
-P0304 Cylinder 4 misfire
-P1399 Multiple missfire detected
after looking it over we discovered the exhaust manifold cracked in half through the o2 primary sensor bung. replaced it with a header and it ran exactly the same. there was discoloration in all but the cylinder 2 runner. so i swapped injectors with another set and even replaced the coil thinking it could be a bad coil. after that the vehicle wouldn't start at all, put the original coil and injectors back in and it fired up but ran the same. swapped 3 different sets of spark plugs, gapped at .044". and still the same. reset the ECU and still the same. did a compression test and it's an even 170 across the board.
now it's just tripping the P1399 code.
also it will run perfect if you mash the gas and wait about 2-3 seconds, it will seem to clear up and pulls hard.
i'm stumped as too what's going on, took the coil to NAPA and had them test the original coil, the new one and another one on the shelf. all of which tested out of range across the primary circuit. not sure if this means all of the coils were bad or if the information i have is wrong on how much resistance they should have. the only thing i have yet to check is timing, but it being an interference engine i'm pretty sure the valves would slam into each other and you would notice it on the compression test and it would be a very noisy top end.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Mar 24, 2011 | 07:14 AM
cjackson2802's Avatar
ive had motors be 1 or 2 teeth off timing and cause random misfire code. check the timing marks, you might be lucky.
Old Mar 24, 2011 | 08:31 AM
flatrex's Avatar
crx hatch sedan
Check timing and get back to us
Old Mar 24, 2011 | 12:11 PM
CRAWFORD BUILT
checked timing, it's perfect. fired it up and it ran fine. shut it off and fired it up again and it ran like crap again.
CRAWFORD BUILT
DC Crew Member #23
Old Mar 24, 2011 | 12:14 PM
CRAWFORD BUILT
also it's not showing any codes now, test drove it, checked for codes again and still nothing. but it still bogs and has no power.
CRAWFORD BUILT
DC Crew Member #23
Old Mar 24, 2011 | 03:15 PM
JoKiE crx4294's Avatar
popeye built!
ecu sounds like its done.
Can't spell strength without tren
AAS...It's whats for dinner
Old Mar 24, 2011 | 10:48 PM
CRAWFORD BUILT
^ that's what i'm leaning towards. i'll swap it and see if it fixes it.
I used a thermometer on each individual exhaust runner as it was running, each cylinder was the same +/- 5 degrees. also there is even discoloration on all runners now.
CRAWFORD BUILT
DC Crew Member #23
howeeez
May 8, 2010 11:58 AM
stealth gt92
Mar 5, 2010 10:30 PM
Clint
Jan 28, 2008 11:53 AM
DOHC_VTEC
Jul 8, 2002 06:09 PM
