Running like crap at WOT - please HELP!!!!
Just finished the H22A Accord swap. Been running for 3 weeks now and when driving normal, its great,but at WOT, the motor hesistates n bucks like crazy especially when Vtec kicks in. This happens only in 2nd and 3rd before and after Vtec engages.
No CEL.. idles fine. new plugs,wires,caps,fuel filter, etc, etc.. full major tune up. Running 92 octane. I/H/E cam gears(+2,-2)flywheel/clutch.
What could it be? Am I running lean or something? When we dyno it after the swap was done,183 hp/151 tq, right before Vtec, the power just fell flat on its face and jumped right back up at Vtec. This explaines the harsh yank/buck right before Vtec kicks in. I still don't see why its bucking or hesistating through out the power band.
It goes something like this:
1st gear - 1k ------5k------7.8 ->smooth
2nd 4k ----..5k-.-.-.----7.8 ->harsh/hesistation
3rd almost the same as 2nd gear.
Any help would greatly be appreciated. Thanks
sounds to me allmost like it's lean, but for it only happening in 2nd and 3rd??? i'm stumped , try raising the fuel pressure.
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
14.729 @ 94.79
I'm running the P13 with no CEL so I don't think its detonating. Gas - well I tried a booster and run 92 octane from shells,race track, 7-11. I don't see that being the problem. I think its getting mad air and its chocking at WOT. I don't have an adjustable FPR so I tried unplugging the vacume hose off the stock FPR and cap it. I figgure unplugging it will raise the pressure up a bit. Still ran the same. SUCKS!!!
I appreciate you guy's help. Thanks again
Guest
Posts: n/a
My gu355 15 50m37h1|\|g 1g|\|1710|\| |23l473d. |\|07 d370|\|4710|\|. C0uld b3 4 1CM 7h475 0|\| 17'5 \^/4y 0u7, 0|2 4 b4d g|20u|\|d. Y0u'd b3 5u|2p|2153d h0\^/ 51mpl3 l177l3 p|20bl3m5 l1k3 7h353 c4|\| m4k3 d|21v4b1l17y h3ll. \^/3'll h4v3 4 l00k513 47 17 500|\| buddy :\^/4v3:
Originally posted by "Mr Self Destruct"
My guess is something ignition related. Not detonation. Could be a ICM thats on it's way out, or a bad ground. You'd be surprised how simple little problems like these can make drivability hell. We'll have a looksie at it soon buddy
________________________
