why is my car running like crap?
Old Feb 4, 2010 | 08:23 PM
stealth gt92's Avatar
Default why is my car running like crap?
the car doesnt want to idle very well it when it does it idles high to prevent stalling.i have a 70mm bbk t/b on it and it makes all sorts of noise whistling real loud in and out like its breathing i think it might be broken somehow?. and it goes in out of tune. one minute it will be driving good next minute hesitating and stalling constantly. the rpms while driving kind of go crazy like the computer and the gas pedal want to do two different things so the idle and rpms are both going up and down randomly.it has aluminum heads and a trickflow cam and intake.the motor was out of a 95 5.0 but has 91 computer and is all set up for a fox.im just trying to figure this out any new input would be appreciated besides to go carb
Old Feb 4, 2010 | 08:34 PM
notchback93's Avatar
The whistling noise is normal with a BBK! You might want to get a custom tune or have the tps check out!
Old Feb 4, 2010 | 08:39 PM
riverviewnative's Avatar
Probably the guy who did you hci. My Guess since when you and i did the intake it ran fine. Should have just bought it to me to do that stuff. Lesson leard. Hope it works out for you. try changing your ecm
Old Feb 4, 2010 | 08:42 PM
willie_massacre's Avatar
Lives in a square
Im pretty positive its because its a ford. but
Old Feb 4, 2010 | 09:26 PM
GNs-r-slow's Avatar
Bondsman
Time to take it to a tuner...
Old Feb 4, 2010 | 09:31 PM
Naa I have done a bunch of hci with no tune and no issues
Old Feb 4, 2010 | 09:54 PM
GNs-r-slow's Avatar
Bondsman
And without a doubt, you can do the basic tuning that most over look. TPS, IAC, timing blah, blah, ect.
Old Feb 4, 2010 | 10:06 PM
i had all the motor work gone through by shaun and it was good.i tihnk its just tuning if you think you can lend a hand raymond i can drive her over and see what we can do. plus i need some parts let me know if you wanna get together.
Old Feb 5, 2010 | 12:00 AM
Iraq&Roll's Avatar
Could be many different things... Check the 10 pin connectors (black and white-salt/pepper) between the firewall and the upper intake. Make sure there is good contact between the male/female pins. Pull them apart and gently spread the male pins so they make good contact. It is free and may/may not help your problems.
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Old Feb 5, 2010 | 06:48 AM
^ checked salt/pepper connectors started the car it fired up idled good and then i drove it around the block and it started doing the same shit and then i shut it off and started it back up and it wouldnt idle and was surging and hesitating again so idk.
