help crx ls swap in limp mode..
Old Feb 27, 2011 | 06:21 AM
ekcoupe's Avatar
IS FASTER THAN YOU
Default help crx ls swap in limp mode..
alright 90 crx
ls swap
runs great if u drive 80% throttle .
but if ur if u just hit it and go wot for a couple seconds.. check engine light comes on and it boggs and falls on its face and wont go past 3k rpms..
i have to turn key off to reset ecu and then its fine again.. ..
please help rep will be given .. i was told it was throwing tps code. idk ..
Old Feb 27, 2011 | 02:11 PM
ekcoupe's Avatar
IS FASTER THAN YOU
any body had this problem
Old Feb 27, 2011 | 07:03 PM
eightwun3zfynest's Avatar
sleeper
change the tps sensor, same thing happened to my h22 sol when it was throwing a tps code
Old Feb 27, 2011 | 07:10 PM
BoostedRacerDad's Avatar
Pops
Try adjusting your TPS first, but might need replacement. This is how to do it however I dont see why he removed throttle body. How to replace and adjust your TPS - ClubIntegra.com - Acura Integra Forum
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Feb 28, 2011 | 03:42 PM
ekcoupe's Avatar
IS FASTER THAN YOU
thanks guys rep sent.. yea i was told to check the calibration .. i didnt know if it could be reset or just replaced.. but ill throw a new one on there. .. thanks again..
95gainfla
VW/Audi/Porsche Tech
5
Sep 9, 2010 04:57 PM
MadeAStinky
Apr 11, 2007 07:18 PM
Juiced Dc2
Aug 30, 2006 05:40 PM
myltwon
Feb 7, 2005 09:06 PM
