Good d16 turbo combinations? what can it handle??
Old Feb 8, 2011 | 03:29 PM
b15spec's Avatar
aint no reg. spec-v
i wasnt planning on using 24lb lol, the vitara pistons i was going to go with, hold anywhere from 16-20lbs of boost, hopefully i can get that with the mods i was going to use, the head will be built, and i know im going to use forged rods, with the vitara pistons to say the least.
Old Feb 8, 2011 | 07:18 PM
Alex H.'s Avatar
Registered EF driver
Yeah bro, those Vitara pistons will hold a lot of boost believe it or not, you would be surprised.
1991 Honda Civic Hatchback Si complete USDM OEM Honda restoration in the making.
TR "Old Skool EF" Member #208
Cell: 727-452-7280
Old Feb 9, 2011 | 01:58 PM
b15spec's Avatar
aint no reg. spec-v
yeah, just wondering how much they can really handle 16-20lb doesnt really tell me the most just between, dont want to do a lb or 2 over and be screwed.
Old Feb 9, 2011 | 06:27 PM
Skee's Avatar
you can make 300whp with vitaras , rods and bone stock head with the right setup
if ya run vitaras make sure u get the fj custom rods to take up that extra loss in compresstion running the vitaras
im doing the same build shotting for 300whp
Custom high amp Alternators.. pm me
Old Feb 9, 2011 | 06:44 PM
b15spec's Avatar
aint no reg. spec-v
Originally Posted by Skee
you can make 300whp with vitaras rods and bone stock head with the right setup
you mean pistons? and tats good to hear on a pretty much stock motor, with built head hopefully get some more flow and more power! How much boost you plan on using?
Old Feb 9, 2011 | 06:46 PM
sxysweed's Avatar
CRX.XXX
So much fail in this thread.
PSI doesn't matter, horsepower does.
Stock rods fail somewhere around 220whp (typical tq curve).
You can easily max out a T3/T4 57 trim on a D16.
SpeedFactory was making 420whp on a T3/T04E 57 Trim (.63 a/r) and the Bisi 2.4 (stock Z6 ports)
Vitara's have held 600whp before.
And yes, 400whp has been done on a stock head/cam. Different cam can certainly widen the power band though.
And boosting a D isn't different. It's smart.
Old Feb 9, 2011 | 06:49 PM
  #17 (permalink)
Skee's Avatar
na ment to say vitaras and forged rods // also if you lookin for 300 and on a budget you can use b series ls rods im using b series rods in mine with heat transfer coating
Old Feb 9, 2011 | 06:54 PM
  #18 (permalink)
b15spec's Avatar
aint no reg. spec-v
is that a bisimoto 2.4 cam? and in my case im not looking to rebuild my motor anytime soon, just dont want to rebuild my motor by putting too much boost to it, if you know what amount of "PSI" can you put thru the pistons til its near the limit, i dont see how it wouldnt matter, because too much boost will put any motor down.
Old Feb 9, 2011 | 06:55 PM
  #19 (permalink)
b15spec's Avatar
aint no reg. spec-v
thats what i figured, and i heard about the ls rods, but my power goal is above 300, so they are out of the question.
Old Feb 10, 2011 | 02:53 AM
  #20 (permalink)
Skee's Avatar
no psi dont matter its just how much power you build can handle
if you have a small turbo and 20 psi compare to a larger turbo and 20 psi big diffrence in power
