NEED HELP! My DD wont start, just shut off while driving.
Old Jan 1, 2011 | 09:30 PM
  #21 (permalink)
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Originally Posted by rangcrx
If u need ur head done let me know.I would be more then happy to do it.glad to hear they did not hit.that saved u alot of trouble.as for valves I will give u what ever u need I got boxes of them
Any standard size stainless valves?
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old Jan 2, 2011 | 06:16 AM
  #22 (permalink)
chi town brat's Avatar
! Ne shab'rud'ni !
This sucks to hear. Does anyone else think he may need to check his valve springs as he spoke of using a higher compression piston or is the timing belt the only culprit here?
Old Jan 2, 2011 | 11:58 AM
  #23 (permalink)
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Not really its not like he put a bigger set of cams that will hurt his valve train but it doesn't hurt to have them checked out. Be safe than sorry
Old Jan 2, 2011 | 06:34 PM
  #24 (permalink)
Brandon H.'s Avatar
Thanks for everyones help so far, I will be needing to get a few paypal addy's from a few of yall sometime this week.
rang, im very happy to hear your willing to help, possibly you could look at it for me? You in Tampa? PM a number or address or something. Im trying to figure out prices and what all I will need,
I will be needing new headbolots correct? How much are factory bolts vs ARP's? Trying to save what I can, since its a mild motor. Im thinking of going with a Gates timing belt. Also what about a new belt tensioner??
Here are pics.
Top of valve stem looks smashed
Head pulled off, bleeding
The head
Cyl # 4
Cyl # 3
Cyl # 2
Cyl # 1
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Jan 3, 2011 | 12:23 AM
  #25 (permalink)
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Looks kinda like the valves were too tight. To need to figure out what cams you have a adjust the valves. If rang doesn't help ill help either way it'll be done correctly. He's one of the best around
And arp headstuds are around 130 which are cheaper than OEM from Honda just make sure to get b16 ones because Gsr are slightly longer
Old Jan 3, 2011 | 03:49 AM
  #26 (permalink)
Brandon H.'s Avatar
Well I did the leakdown test with the cams out so allvalves should have been closed. I have checked the valve last a month before and all was good.
1999 Honda Civic Si
TR em1 crew #43
Old Jan 3, 2011 | 04:55 AM
  #27 (permalink)
rangcrx's Avatar
engine building &best
Yes im in tampa..
i love AUTOZONE
Old Jan 3, 2011 | 04:31 PM
  #28 (permalink)
Brandon H.'s Avatar
Any idea what kinda pistons those are? They are bigger then the PR3's I have laying around.
EJ-6, hows that guys prices that you recomended?
1999 Honda Civic Si
TR em1 crew #43
Old Jan 3, 2011 | 06:52 PM
  #29 (permalink)
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Those pistons are pct which are civic type r pistons
Hos prices aren't outrageous they are good prices. Depends on the damage. Tell him Jordan sent you he will hook it up
Old Jan 4, 2011 | 01:27 PM
  #30 (permalink)
Brandon H.'s Avatar
Hey Jordan I called that guy, left a message and haven't heard back from him. So I'm still looking for someone to look at this head
1999 Honda Civic Si
TR em1 crew #43
