NEED HELP! My DD wont start, just shut off while driving.
Old Dec 29, 2010 | 05:58 PM
Brandon H.'s Avatar
I have a feeling my shit is fucked. Advice still needed. Timing is way off, compression test got me 20 psi. It might be low because I either bent the fuck out of the valves, or because a valve is open during compression stroke. Timing best is missing atleast 10 teeth, im not sure how it happend. I am thinking about pulling the cams out and trying a compression test or leakdown test with my tester but im sure im pulling the head this weekend anyways. First time ever going this far into a Honda motor.
Pics
Number 1, TDC on compression stroke. As you can see the marks are off.
Belt is fucked
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Dec 29, 2010 | 06:14 PM
rangcrx's Avatar
engine building &best
Lol wow that fucking sucks yes if I was u I would remove the cams and do a leakdown im guessing it will not be good tho....sorry for ur problem
i love AUTOZONE
Old Dec 29, 2010 | 06:16 PM
flatrex's Avatar
crx hatch sedan
Yikes
Old Dec 29, 2010 | 07:34 PM
Brandon H.'s Avatar
Yeah it sucks. What are the chances the bottom end is still good? I'm guessing if a valve bent then it fucked up the valve seats?
1999 Honda Civic Si
TR em1 crew #43
Old Dec 30, 2010 | 06:32 AM
wakeking48's Avatar
Yes!!!!
Bottom end may still be good depending on how far the valves dropped when your belt went out, but im pretty much positive your head will need machine work and a few new valves
2001 King Ranch F.150 (sold)
1991 5.0 Ls mustang (sold)
1993 ls cx hatch (traded)
1995 b16 eg coupe (SOLD)
2007 Hyundai Tiburon (sold)
2006 Yamaha R6 (sold)
1995 jdm b20b integra (sold)
2006 Mitsubishi fp red evo (dd)
Old Dec 30, 2010 | 06:50 AM
rangcrx's Avatar
I doubt u did much damages if u have a stock b16 cam.if u bend a valve the seats will be fine its the guides that get chipped
i love AUTOZONE
Old Dec 30, 2010 | 10:56 AM
  #17 (permalink)
Brandon H.'s Avatar
Well I do believe it has stock cams. I didn't see any marking on the exhaust cam when I took the cam cap off behind the vtec solenoid.
How bad would this damage the pistons? Could it damage anything else in the bottom end? Would a something like a valve hitting the piston would that damage the engine bearings at at?
1999 Honda Civic Si
TR em1 crew #43
Old Jan 1, 2011 | 09:49 AM
  #18 (permalink)
Brandon H.'s Avatar
Pulled the cams and did a leakdown. It's leaking a lot on the exhaust side, and on the intake side on #4. I even tapped on the valves with the handle of a hammer. Pulled the head and I don't see any signs of the valve hitting. No marks, lots of loose carbon thought. The pistons are not PR3's, they are higher compression pistons, not sure what kind though.
Are there any cheap valves out there?
1999 Honda Civic Si
TR em1 crew #43
Old Jan 1, 2011 | 10:22 AM
  #19 (permalink)
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Call rays performance machine shop he gets good deals obo valves. His cell is 813-368-8006 tell him Jordan sent you he will Hook it up
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old Jan 1, 2011 | 02:13 PM
  #20 (permalink)
rangcrx's Avatar
If u need ur head done let me know.I would be more then happy to do it.glad to hear they did not hit.that saved u alot of trouble.as for valves I will give u what ever u need I got boxes of them
i love AUTOZONE
