Teg falls on its face...
Old Oct 30, 2010 | 02:49 PM
  #21 (permalink)
BoostedRacerDad's Avatar
Pops
Could be most anything already mentioned.
Plugged cat, engine cant breathe.
Bad dizzy, plugs, wires,cap
clogged fuel filter, weak pump, bad fuel pressure regulator
wrong Map
Is car throwing any codes?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Oct 30, 2010 | 03:26 PM
  #22 (permalink)
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
wrong Map
definately+1.....remember start and eliminate the simple stuff first....ohh and a cat being plugged wont allow the engine to breathe, the exhaust is backing up into the engine and not able to flow....
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Oct 30, 2010 | 03:43 PM
  #23 (permalink)
lopezchris21's Avatar
Car has new fuel filter, plugs, wires, and timing is on the money again. Marks line up perfect with oil pump and what not. Car does not tick or tock or anything so it can't be a spun bearing. I went to a shop and have the tuner look over my ecu and he said it's a stock b16 base map. I got the 99% stock. Only aftermarket thing was the ecu.
TR 5th Gen Civic CREW Member # 04
Old Oct 30, 2010 | 03:45 PM
  #24 (permalink)
Ordered a test pipe to finally eliminate the cat and ordered a walbro. Basic things I need done anyway with my future build.
Old Oct 30, 2010 | 04:13 PM
  #25 (permalink)
2qk4u's Avatar
check injectors and map sensor. i had a bad problem with my map sensor and it never threw the code.
Old Oct 30, 2010 | 07:09 PM
  #26 (permalink)
mogo21's Avatar
sounds like its a tooth off , it only takes one tooth to make it run like complete shit
Old Oct 30, 2010 | 08:55 PM
  #27 (permalink)
Secondz's Avatar
Built Not Bought
Sounds like you need to get out of the honda game for good.
Old Oct 30, 2010 | 09:11 PM
  #28 (permalink)
hondaking625's Avatar
DB1 FTW!!
lmfaooooooooooooo^^^^^^^
Old Oct 30, 2010 | 09:14 PM
  #29 (permalink)
Ls_[eg]hatch's Avatar
mowchowbrowncow
im about to do the same.
E36 m3 here i come.
Old Oct 30, 2010 | 09:17 PM
  #30 (permalink)
Thatguysstuff's Avatar
Hey its that guy!!
any CEL? my CL is doing the same shit...
