Teg falls on its face...
Old Oct 30, 2010 | 04:42 AM
lopezchris21's Avatar
It has a p28 chipped with conversion harness and clutch isn't slipping
TR 5th Gen Civic CREW Member # 04
Old Oct 30, 2010 | 04:43 AM
zhillz's Avatar
Porno Music Producer
It's chipped because he says so?
Had the ecu looked at a couple weeks ago and they said it was a b16 chip but that still wouldn't make my car fall on it face and run sooo slow. We talking bout a single jingle stock would eat ne
Old Oct 30, 2010 | 04:44 AM
No u can see the socket and stuff in there
Old Oct 30, 2010 | 04:58 AM
Old Oct 30, 2010 | 05:01 AM
Don't mind the loose belt
Old Oct 30, 2010 | 05:54 AM
  #17 (permalink)
Dayum wat happened to all the techs that used to come in here?
Old Oct 30, 2010 | 08:07 AM
  #18 (permalink)
BlackWind's Avatar
Requiem
it sounds to me like yo umay have spun a bearing, i had that happen in an h23 lude i had in early 07.
Old Oct 30, 2010 | 08:18 AM
  #19 (permalink)
amendoza's Avatar
it can be a chipped p28 but what map is on it? it can be 4 a turbo setup? how do u know it's for a b16 setup because your friend told you so? try that computer on any of your friends cars to see if it acts up on there car and you will illiminate that problem.... if not check timming marks on the cams...... maybe a off
Old Oct 30, 2010 | 11:55 AM
  #20 (permalink)
sullivanracing06's Avatar
Timing!!!!!!!!!!!!!!!!!!!!
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
