b16 head build question
Old Sep 14, 2010 | 07:58 PM
  #21 (permalink)
xch1nksterxbo1x's Avatar
is it hard to explain? and im kinda new to this world lols..
Old Sep 14, 2010 | 08:01 PM
  #22 (permalink)
MightyMaxGS-T's Avatar
you have parts, but you need the right combination. you already bought the pistons?
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Sep 14, 2010 | 08:02 PM
  #23 (permalink)
yes i did..
Old Sep 14, 2010 | 08:08 PM
  #24 (permalink)
ok you should run a thinner head gasket to get your compression ratio over 12:1. porting is the process of opening up the ports on the and smoothing the ports to make it flow better.
Old Sep 14, 2010 | 08:14 PM
  #25 (permalink)
okay where would i order that head gasket at? and porting is making your intake and exhaust ports bigger right?
Old Sep 14, 2010 | 08:16 PM
  #26 (permalink)
its not so much about making it bigger as it is about making the head flow better. its hard to explain but you need it lol and i got a guy.
Old Sep 14, 2010 | 08:18 PM
  #27 (permalink)
also, the head gasket that comes with the vtec conversion kit, Is that an thin head gasket that will bring my compression ratio 12:1?
Old Sep 14, 2010 | 08:22 PM
  #28 (permalink)
Unported:
My head, ported:
Old Sep 14, 2010 | 08:23 PM
  #29 (permalink)
no that is oem thickness.
Old Sep 14, 2010 | 08:49 PM
  #30 (permalink)
where can i get an thinner gasket?
