sohc boost questions
Old Sep 13, 2010 | 12:33 AM
travishoward's Avatar
Default sohc boost questions
im gonna be running an obd1 jdm d15b vtec-e block, with a d16z6 head, d16y8 intake manifold, b18b1 throttle body, .020 cometic headgasket, and arp headstuds, stock internals
compression will be at 8.04:1, i plan on using a t28, 310cc injectors,93 octane and a walbro 255 fuel pump, at 12psi
the effective compression ratio will be at about 14.6:1
will this be safe for daily driving?
many other forums say it will, just none are on this exact setup
please bring positive feedback only
ill rep everyone who helps
whats an estimate for a dyno tune on this setup?
and can i use my phearable p28 ecu if i get it retuned?
thanks everyone, and sorry for the newb questions
Old Sep 13, 2010 | 04:58 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
1. i wouldn't run stock internals.
2. i'd go atleast 550cc's on the injectors.
3. tuning depends on how many headaches the tuner runs into while working on it. they usually charge by the hour.
go with h-beam rods, high silicon pistons, a good set or cams (something around a 280/280) and get a good set of valve springs.
then once you get the parts take it too a machine shop and completely rebuild it, have the head surfaced and the valves re-faced, and have every gasket/seal in the motor replaced.
do it the right way. don't just swap heads and slap a turbo on it.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Sep 13, 2010 | 05:10 PM
FoxHondaRider's Avatar
Registered Hater
^ its a D series lol. This isnt some high end expensive motor, slap that shit together and call it a day. When it blows, buy another motor for $200 or upgrade to something better.
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Sep 13, 2010 | 05:15 PM
CRAWFORD BUILT
if that's what he wants to do then more power to him. he'll do that if he wants to go slow. i've said it before and it never gets old, speed isn't cheap.
CRAWFORD BUILT
DC Crew Member #23
Old Sep 13, 2010 | 07:02 PM
sxysweed's Avatar
CRX.XXX
If it's a D16-rods based D15B, then you'll be fine to about 220hp on stock internals. On a regular D15, maybe 180whp is it. D16A1's (old 'teg motors) have slightly thicker rods, not sure on the DOHC ZC's though.
Anything past that is pushing it. If your gonna build it, just do a basic Vitara Build. You can have all new bearings, most seals/gaskets, Pistons/Rods for less than $700 easily. You still need a few things though.
Old Sep 13, 2010 | 07:53 PM
Blocks are easy to come by. That's what I wanted to do. Don't have thousands for a sohc. I got this motor on accident and I'm trying to make the best of it. Thiers still questions I need answered though. Mainly the comp ratio being so high at 12psi. I'll rep y'all as soon as I get to a pc and not an itouch. Thanks for all the help y'all!
Old Sep 13, 2010 | 08:35 PM
wakeking48's Avatar
Yes!!!!
Ugh o i wonder who is going to be boosted in the group first me or you
2001 King Ranch F.150 (sold)
1991 5.0 Ls mustang (sold)
1993 ls cx hatch (traded)
1995 b16 eg coupe (SOLD)
2007 Hyundai Tiburon (sold)
2006 Yamaha R6 (sold)
1995 jdm b20b integra (sold)
2006 Mitsubishi fp red evo (dd)
Old Sep 13, 2010 | 10:56 PM
haha, who knows, you make more money so if thats your plan then probably you.. whyre you goin sohc?
Old Sep 13, 2010 | 10:58 PM
whats the best tranny too? i can get a dx, but would thier be anyothers that are better?
Old Sep 14, 2010 | 07:39 AM
BOB's Avatar
BOB
Too Old & Too Poor
Try to pick up a ex/si model transmission. Look for the code B000 stamped in a small circle near the drain plug area of the transmission. Those models have the shortest gearing for the D-series, but it's still long compared to what's offered for the DOHC guys.
Search the forced induction Frequently Asked Questions on www.d-series.com to help yourself out. Looks like you've got most of what you need covered.
Now rolling in a partial zero emissions vehicle.
