sohc boost questions
your set up can be built with the best name brand parts but it all comes down to engine management and the tuner.......
you can have a built motor and a ok/shitty tune and your 1000.00 rod/piston set is going to be toast..
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
the manifolds are shit.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
the cast ebay manifolds are ok tho...
i made 231whp on a 12psi spike on a completly stock D15b motor with 770cc injectors and a ex short gear tranny with a stage 1 clutch.. good luck the the D build
boosted 98civic 4dr 231whp SOHC DD - traded
97 Civic EJ6 hatch 41MPG SOHC - Current DD
