h22 shifter cable problem
Old Jul 13, 2010 | 10:59 PM
OldSchool Mike's Avatar
Civic Duty member #001
Default h22 shifter cable problem
problem is i cant get into reverse and now even the other gears are givin me trouble but reverse just dont go in. and the one other time i actually got in reverse it got jamed and wouldnt shift anywhere so i bought some nice cables and still the same HELP!!!!
Old Jul 14, 2010 | 02:29 PM
mox92's Avatar
Ek
might be the tranny or the way the cables are mounted could be rubbing on something
Old Jul 14, 2010 | 06:24 PM
NeKe1point0's Avatar
Possible causes:
cables not secure at shifter
cables not secure at tranny
bad clutch disc/pressure plate
bad hydraulics
bad tranny
check them off until you find your issue. GL with the fix
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Jul 16, 2010 | 04:02 AM
thanx guyz i got new cables and re ran them so they wouldnt bind up on anything all my cables are secure and now i hall all 5 gears but no reverse!!!!
Now what do i do?
Old Jul 16, 2010 | 09:59 AM
Originally Posted by NeKe1point0
Possible causes:
bad hydraulics
bad tranny
Are you sure the tranny is good ?
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old Jul 16, 2010 | 04:08 PM
ye3ah it was fine before. but what are the odds its my hydraulics?
should i be able to put the car in all gears without pushing in the clutch with ease.
