LS Cank question
Old Jul 3, 2010 | 02:46 PM
  #31 (permalink)
Ls_[eg]hatch's Avatar
mowchowbrowncow
Originally Posted by rangcrx
no problem i can get new arp vtec rod bolts for 63$ you dont need mains just stick with your stock ones..
ight well prolly not the friday closest to us but the friday day after the 16th ill have the cash for them
Old Jul 29, 2010 | 03:12 PM
  #32 (permalink)
MightyMaxGS-T's Avatar
Originally Posted by 88_Hatchy
You are better off using a B18C crank in a B18C block. The 0.2 bump in compression and very slight torque increase are not worth the trade offs. With the LS crank you have to either modify the rods or get after market ones. Even if you get ARP bolts and have the shot-peened, the big end will still oval at high revs. A good set of after market rods cost more than a set of Eagle rods. You will also most likely have to block off the oil squirters, which is taking away from the advantages of using a B18C block in the fist place.
have you ever done it? the rods do not need to be modified and they dont oval at high rpm, there is no reason they would as long as you have them resized BEFORE you build the motor. i have done this setup and it runs well and is reliable. i eliminated the oil squirters and had no issues. make sure you use an ls crank with ls rods and ls/b20 bearings. i hate when people down talk about shit they have never done. if you have any questions on this build shared_pm me and i will answer them for u.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Jul 29, 2010 | 03:22 PM
  #33 (permalink)
How is the GSr crank not "better"? Better balancing from the factory, better bearing choices, the stock rods that fit a GSR crank are better. There are also better ways to raise compression than swapping cranks.
Never have, never will.
You're right, it will be safe and reliable if built correctly. Most people do not invest enough time and/or money to do things the correct way. People run much larger cranks than 89mm, but they are not always the best choice. Oil jets are one or the advantages of a VTEC block.
Do you really think that the OP would benefit from swapping a LS crank in a B18C block? The amount of money needed to correctly swap a LS crank would/could/should be better put towards other modifications, especially if the OP already has a complete bottom end. A stock GSR bottom end will rev higher than 8K, without having to have rod bolts installed, have resized, or have the small ends shaved down to accept B16 pistons.
Eagle rods are cheap Chinese crap and, IMO, garbage. They work, but there are much better choices available.
i built this same setup, rev'd it to 8900 everyday. oil squirters aren't really a big deal and removing them doesnt harm the motor. the small ends of ls rods do not need to be shave to accept b16 pistons, that is only true with itr pistons on ls rods. putting an ls crank in a gsr block is not as hard or expensive as you are making it seem. maybe you should try build one before speaking about it.
Old Jul 29, 2010 | 03:58 PM
  #34 (permalink)
88_Hatchy's Avatar
I'm cooler than you
8900 isn't all that. Do you really think Honda engineers would have fitted VTEC blocks with oil squirters if they weren't "all that"? I would bet they know more about them than either you or I. I would consider building an B18B with a LS crank if my B18C1 engine didn't already make more torque than most LsVTECs. I have been thinking of building a B20VTEC, but I haven't finished my current engine yet and I would rather K-swap the car instead.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Jul 29, 2010 | 04:27 PM
  #35 (permalink)
i have built more motors than just honda, some have oil squirters and some don't. the fact that a motor is lacking oil squirters doesnt make or break the build, the builder does. all that other shit about oval rod ends is crap tho. i don't need to speak with honda engineers to know that it works, i have done it and the proof is on youtube. you could have a million of them tell me it doesnt work and i would still go against it because i have done it already. if you made good torque numbers with ur gsr stroked motor imagine what you would make with a longer stroke? although you made good numbers, doesnt mean it can't get better.
Old Jul 29, 2010 | 08:15 PM
  #36 (permalink)
88_Hatchy's Avatar
I'm cooler than you
If a LS rod is revved above 9k, even with ARPs, it will eventually oval. Period. The point it, you don't need a LS crank to make decent torque numbers. I make good torque numbers with a 87 mm crank because the build was thought out. I would rather have the security of knowing my engine will last than have the <2 lbs of torque increase and have to worry about spinning a rod.
Suppose one man fucks a sheep, I'm sure more than a million people would say it's wrong. He thinks it works because he did it. Who's wrong here? It works, but it can't possibly be the best.
Old Jul 29, 2010 | 09:47 PM
  #37 (permalink)
USDM4g4d's Avatar
formerly D00MSB08
Im going to quote the second part and sig!
R.i.p My Big Brother Pablo Garcia III 9.28.85 - 9.05.07
The Man, The Myth,
The Legend.
Power Of DREAMS.
Originally Posted by K20A2
Nothing wrong with a B series
Old Jul 29, 2010 | 10:48 PM
  #38 (permalink)
mowchowbrowncow
my buddies ls/v has been spinning like 9k for like 3 years now...& is still together & its even seen the bottle.
Old Jul 29, 2010 | 10:50 PM
  #39 (permalink)
that is the stupidest load of shit i have ever heard. what would make LS rods turn oval faster than gsr or b16 rods? nothing. your argument is pointless. there is nothing wrong with putting an ls crank in a gsr block with ls rods. who gives a fuck whether YOU did it or not, maybe you are just a short stroke kinda guy. this combo works and it works well, you know nothing about it because you have never done it. because you have never done it you should have no input. you are speaking solely from speculation rather than fact which just leaves you looking like a know-nothing douche bag.
