OMG-my sh*t still wont fire
it cranks with the key. it acts like it wants to staRT. U hear the exhaust and everything when u start it. just to be sure wars the specs of the valve lash supposed to be? i did .006 in intkae and .008 on exhaust
TR 5th Gen Civic CREW Member # 04
Unscrew them all not all the way and set them all back a lot then see if your compression goes up don't start it tho...if I was close I would fix it for ya no doubt so u can stop throwing many at it and enjoy it lol
i love AUTOZONE
i love AUTOZONE
Loosen the 10mm then turn the screw give them a gap don't undo the screw all the way then make sure u take out all 4 spark plugs and hold open the throttle body to do the compression check
i love AUTOZONE
i love AUTOZONE
Undo the 10mm then use a flat head turn counterclock wise 2 full turns each if your compression does not go up to at lease 140 or higher then somethings wrong. Do it to intake and exhust side do not I repete do not try and start it like this
i love AUTOZONE
i love AUTOZONE
rang. my car wont start period.... thats my main problem. and counter clokewise isnt that making the space between my rockers and cams larger. so valves wont open as much. imma have to turn my car over for compression also. i will have my dizzy disconnected also.
Your cars not starting cause u don't have the sompression to start it I want you to open the gap to see. How much higher the. Compression I would like to see how high it goes. Ur number r so close together I would say timing needs to be check by some1 who knows qhow
i love AUTOZONE
i love AUTOZONE
