can i turbo a d16z6 without blowing it?
thanx you guys really helpful. i have always wanted a honda and never got one till now. i now got something to do in my spare time.(besides my son crying every 5 min) appreciate the info guys i will keep u posted.
you'll need a fuel system that can keep up with the higher concentration of air, and an upgraded map sensor if going over 11lbs and a good tune on the ECU. stock sleeves can handle ~13-15lbs of boost but no higher because the top of the sleeve will begin to expand and crack due to the added stress load on an open ended block. also check compression to make sure the head and head gasket are still good, and that everything on the motor is in good working order.
I did 26psi stock sleeve with a gt4294..
psi is irrelevant.....
Can't spell strength without tren
AAS...It's whats for dinner
