can i turbo a d16z6 without blowing it?
Old Feb 4, 2010 | 03:11 PM
hondakev's Avatar
Exclamation can i turbo a d16z6 without blowing it?
i got a 93 civic coupe ex with a d16z6 can i turbo it and do it effectively without blowing something up? What additional mods will i have to make or can i do it on a stock engine or is there a cheaper and or better way to get more power from this engine? how much money will i have to invest in this project? thanks.
Old Feb 4, 2010 | 04:46 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
you'll need a fuel system that can keep up with the higher concentration of air, and an upgraded map sensor if going over 11lbs and a good tune on the ECU. stock sleeves can handle ~13-15lbs of boost but no higher because the top of the sleeve will begin to expand and crack due to the added stress load on an open ended block. also check compression to make sure the head and head gasket are still good, and that everything on the motor is in good working order.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Feb 4, 2010 | 04:47 PM
70-yenko-nova's Avatar
lol... mine is turbo.. D16Z6 custom intake and injectors.. and full greddy baby turbo kit just make sure its tuned bro
Old Feb 4, 2010 | 05:06 PM
hondakev's Avatar
price of a good dyno or street tune?
Old Feb 4, 2010 | 05:26 PM
thegoldenchild's Avatar
check this place out and get better informed Turbo D16 • Index page
Old Feb 4, 2010 | 07:31 PM
hondakev's Avatar
what head can i swap to it and how much of a difference will it make. and please excuse my questions they may be easy for you and i am just trying to learn. we all had to start somewhere
Old Feb 4, 2010 | 07:44 PM
no need to change your head, boost what you have unless you have money to spend.
Old Feb 4, 2010 | 07:53 PM
FrodoGT's Avatar
Found the Vtec switch.
Youve already got the best head. Boost that.
TR Old Skool EF Crew #24
Old Feb 5, 2010 | 07:59 AM
juiced2ndgenteg's Avatar
There goes another single cam. Good luck with the rebuild/engine swap.
Old Feb 5, 2010 | 09:08 AM
dippincrx's Avatar
save the s.o.h.c
+1 except for the sleeves. they can hold more than 15. ive seen 25+ no gaurd on stock sleeves no issues.
just keep the power no hight than 230 on a good tune and you should be good with stock internals.
