SOHC VTEC swap questions - Help Quick
Old May 19, 2002 | 07:59 AM
vwbidder's Avatar
I am putting a 96 SOHC VTEC into an 89 CRX Si. I noticed that the VTEC solenoid has a single wire on a connector and a 2 pin sensor. I assume you feed the single wire with +12V to activate VTEC Is the other sensor for?
Also the 96 motor has a sensor at the cranks timing gear but the 89 does not is this sensor nessecary???
And last will the 96 clutch/pressure plate/flywheel work on the 89 Si tranny???
Thanks
God I hate Mullets!!!
Old May 19, 2002 | 08:00 AM
vwbidder's Avatar
Old May 19, 2002 | 08:21 AM
vwbidder's Avatar
Also I have a new intake manifold gasket how do I remove the old one?
Old May 19, 2002 | 09:59 AM
vwbidder's Avatar
Actually I am just swaping the long block. I will be using the SI wireing intake dist etc. I dont even care about VTEC yet I just want to run the correct wire for it to the ECU area for when I do hook it up. I will probably get a Zdyn ECU that is for this app.
Old May 19, 2002 | 11:23 AM
Bill's Avatar
Livin' in Seattle
Originally posted by "Someone"
Yes 12V source to VTEC solenoid wire.
The other plug in question goes to the VTEC pressure switch.
Old May 19, 2002 | 11:28 AM
Bill's Avatar
Livin' in Seattle
I
Crank speed sensor not position sensor. Believe its used for misfire detection.
Old May 19, 2002 | 03:06 PM
vwbidder's Avatar
I am swapping sensors from the 89 to the 96 to be compatible with the 89 ECU The oil sensor fits but what about the water temp sensor? The 89 has a water temp sensor near the oil sensor(first pic). The 96 has what appears to be a block temp sensor near the oil sensor(sesond pic) and a water temp sensor in the flange that the radiator hose connects too (third pic). The 89 sensor will not fit into either hole on the 96 block. What do I do now??? is there a 92-95 sensor that may work.
Old May 19, 2002 | 03:07 PM
vwbidder's Avatar
