clouds and clouds of smoke.
You really need to pull the head off and see what the pistons look like at this point. It sounds like oil to me, which could be anything at this point. You should probably bring the engine to someone who knows what they're doing. The head needs to be rechecked for anything that could be wrong with it, and so does the bottom end.
Unregistered Linux user since 1995.
What the heck is "O" Boost?
http://www.twitter.com/jeffc_sunbelt
sfodder@sunbeltsupport.us
not everything done to this motor was done by the same person. the head was done by carquest and they said everything was fine. The valves seals r new also. The bottom end is where i think everything is happenin. um.. as far as the pcv set up where is the longer hose supposed yo go? i know the short one goes to the top of the block but wat about the long one? valve cover? intake mani? Im not driving my car and all the walls look perfect. I think the oil rings on the piston most likely got messed up while this guy was pushing them in. I am the one that personally gapped them to make sure and yes they were compressed upon installation. Just while pushing them in he had trouble because they wouldnt just slide in...
TR 5th Gen Civic CREW Member # 04
ok so im confused whos motor are we talking about is it your or his or both ...as for the pcv id have to see it but if its setup wrong it could be sucking oil via vacuum and filling the intake runners...if he used a good compressor and they were gapped properly they would have slid in easy with a few bumps of a wooden handle and also did he or you clock the rings properly so that the gaps would not line up and cause blow by
REACH ME @ 813-952-3833 JOE
its my motor and i did a search and i have my pcv system hooked up right. and by clock them if u mean 3,6,9,12 then yes. i made sure they were space out.
and i thought he was using a good compressor just to find out yesterday, i saw the same one he was using for 11 bux at discount. i think he fucked up my rings putting them in.
probably did bro goodluck with all of that hopefully a new set of rings maybe a hone and itll be ok... i like to use hastings rings they seat and break in well
see this bottom end literally has 400 mile on it since i got the shit back from the machine shop. fresh hone, balance crank, new bearrings and all. this is so freaking gay.
lesson learned pay the extra money and have someone that knows what their doing build it for you not some random person.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
