Vtec not engaging, need help!!
Old Dec 27, 2009 | 05:39 PM
LMATOS1104's Avatar
The fan comes on when i turn the car on cold. it stays on and never turns off. I am going to replace the one wire sensor tomorrow. Will post and let you know if the problem is solved. Thanks. You seem to know alot, can you tell me why my car idles at about 200 on a cold start? It doesn't idle high when cold. Can you tell me what it could be?
Old Dec 28, 2009 | 05:14 AM
freakasis's Avatar
the temp sensor is why your car idles weird. and if the fan never shuts off, someone prolly nigerrigged it because they couldnt figure out what the problem is. that too could be why vtec never engages. if it never gets warm enough, no vtec. also why would you change every sensor except the one you have a code for?
"Black people can't be racist" - Some black guy.
Old Dec 28, 2009 | 02:43 PM
LMATOS1104's Avatar
Ok i replaced the sensor, and i still get a code 6. I don't know what else to do! can someone please offer a valid solution, this car is driving me crazy!
Old Dec 28, 2009 | 07:54 PM
RocK EstrellA's Avatar
ORIGINAL OWNER
Low on oil? v-tech wont engage if its low on oil....
K*
Squad
Old Dec 28, 2009 | 08:16 PM
94mightymax's Avatar
first reset your ecu to see if you still get the code.
and i could be wrong but i know on d-series motors the non-vtec ones came with a oil restrictor in the block and if you motor had one and it was not taken out it can be another problem.
Old Dec 29, 2009 | 05:18 AM
freakasis's Avatar
Originally Posted by freakasis
...theres a fault in the wire from the sensor to the ecu.
Old Dec 29, 2009 | 05:19 PM
  #17 (permalink)
LMATOS1104's Avatar
the block that was used was an f22a1, the original was an f22b. I checked for oil flow to the vtec solenoid, and the shit spouted up like old faithful. My car idles low when cold. Someone told me that the ecu is reading that the car is hot, that is why the idle is low. Any ideas?
Old Dec 29, 2009 | 06:07 PM
  #18 (permalink)
freakasis's Avatar
did you check for a problem with the wire? what does the temp gauge read?
Old Dec 30, 2009 | 02:27 PM
  #19 (permalink)
98ek9b20vtec's Avatar
first off the one wire is for your gauge then you have two wires for fan switch and two wires for ect sensor.Was the new block you got vtec? If not it doest have the oil passage to the head to engage vtec like ls vtec have to run a oil line to the head.switch the 2 two wire plugs around
