If you had 3 grand??
Sounds like everyone pretty much agrees on a motor swap. Anyone know where to get a b-series complete swap that can be shipped overseas?? Also my wife has a bone stock perfect condition 2000 civic si. We would like to go turbo with a drag III kit hondata 2b ecu 330cc?? injectors aftermarket clutch. What else would be a smart purchase at the time we buy the turbo?? Ideas suggestions would be great.
Originally posted by "Someone"
Originally posted by Robster
dude like i said it can take time I see b20s go from as low as $450 to $900. An ls tranny is gonna run 350-400. Like I said if you shop around you can have a b20 and tranny for less than a grand. If you spend more than a grand for axles/ecu/shift linkages/mounts then youre dumb.
Im still toying with the idea of doing something like that but Id opt for the higher compression JDM B20 and toss a close-ratio gearbox on it (something like a B16 tranny). Toss on a lightened flywheel some smaller wheels and youve got yourself a torquey little auto-x monster.
yeah rob I was going to say that but swap is the way to go regardless of the block do some research......and get some suspension.
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
damn robster you got your heart set on that damn b20 you need more than 3k to get that bad boy running right running right an relible(aka re-sleve it cause stock b20 sleves aint gonna cut it an he will need to pick up trannyheadpistonsrodsecu..ect) just buy a gsr. if you goin to bulid a b20 you gotta do it right an that means big $$$$$$$$$
: bounce:
: bounce:
97 ITR-Mugen Equiped
04 Honda 600RR
04 Honda 600RR
