Type-R vs GSR
Old Oct 12, 2009 | 07:23 PM
AllShowNoGo's Avatar
type R ftw got both a JDM gsr and a JDM type R
Old Oct 12, 2009 | 07:58 PM
rangcrx's Avatar
engine building &best
Originally Posted by mugen_tuner664
Yeah. Looking at a lot of them, the lift isn't much larger but the duration... DANG!
Yes the buddycluc cams are a very MEAN cam!!! what cams were you thinking of going with?
Originally Posted by FoxHondaRider
Same bore, stroke... Rods are lighter and stronger, pistons are higher compression and molydeblum coated. Pistons are what change the compression ratio over the GSR. I have a write up on another site I did about all the differences, I could list them all if you wish lol
i would like to see it/
wish i had nice toys like this,guess i will stick to my D15 8valve monster
i love AUTOZONE
Old Oct 12, 2009 | 08:47 PM
juiced2ndgenteg's Avatar
If your going to change pistons, pr3 or p30 pistons would be a better choice imo.
Old Oct 13, 2009 | 01:12 AM
mugen_tuner664's Avatar
future drift track owner
Sorry for sounding uninformed but what are the PR3 and P30 from? And I was under the impression that the GSR and Type-R have the highest compression and I want to try to go up while still using honda parts.
And to answer your question Rang, I'm leaning more toward the Skunk2 Tuner stage 2.
Old Oct 13, 2009 | 01:14 AM
And definitely Fox, if you could post a link that would be AMAZING! Like OMG totally radical! I'm trying to get as much info as I can before I do anything.
Old Oct 13, 2009 | 04:58 AM
rangcrx's Avatar
the pr3/p30 come from the b16 motor the p30 will give you the safest highest compression and still being able to you 89/93 gas..the skunk2S2 are a great cam with great specs for your goal..
i love AUTOZONE
Old Oct 14, 2009 | 11:20 AM
  #17 (permalink)
What kinda of compression would I be looking at? Because the Type-R's will put me close to 11:1 and as far as I know they don't run higher then 93 octane
Old Oct 14, 2009 | 11:09 PM
  #18 (permalink)
The pr3's came in usdm b16's and first gen jdm b16's. The p30's only came in second gen jdm b16's. The reason that the b16 pistons give you a higher comp ratio is because the b16's have a lower compression height compared to the b18 blocks. When you put them in a b18, the higher comp height bumps the compression up higher than you'd get in a b16 block. The pr3's will put you at around 11.5:1 and the p30's will get you up in the 12:1-12.5:1 range. You can run 12.5:1 compression on 93oct without and problems. It will give you the most HP/TRQ on 93oct. I ran 12.5:1 on a lsV about 5yrs ago and made 214whp with CTR cams and a P&P b16 head. It was a sweet NA setup. Pegged rev limit from a roll in 1st once vtak cracked at 4400, with 205/50/15's. Also, running the highest comp that you can still run 93oct allows you to get a race gas tune and get another 10-15whp whenever you put race gas in your tank and just swap the pump gas chip with the race gas chip.
Old Oct 16, 2009 | 06:44 PM
  #19 (permalink)
mogo21's Avatar
Pr3's and P30 are b16 pistons and give u a much higher compression ratio than the type r or gsr , thus making more power with the proper combo of supporting mods and tuning
Old Oct 17, 2009 | 05:29 PM
  #20 (permalink)
s2kAdam's Avatar
Project in progress.
i think iv cam to a conclusion.. save the hassle and buy a v8
