ZC info please
just want to know what a zc ACTUALLY is what is the base block? what is the head? cams? bore stroke what crank does it run?
just wondering... jackson sells a blower for them too.
Eat a live toad every morning, and that will be the worst thing to happen every day.
there is an obd 0 zc and an obd 1 zc. the obd 0 zc came in 88-91 crx sis in japan. here are the specs on the zc. its very similar to the D16A8/9 found in us integras. not a bad deal for $600 or so. bolting the engine into a crx with an si transmission makes for a quick little car. my dad did this swap and hes happy. in my opinion its better than a mini-me or swapping in a single overhead cam d16z. dohc engines have more potential.
Displacement: 1595cc
Power (bhp@rpm): 137@6800
Torque (ft/lbs@rpm): 108@5700
Compression Ratio: 9.5:1
Bore (mm): 75
Stroke (mm): 90
Cam Design: dohc
Bore (mm): 75
Stroke (mm): 90
Cam Design: dohc
