AEM wideband help
Old Aug 19, 2009 | 05:47 PM
custom240sx's Avatar
DC Crew Member #1
I got my lc-1 for $160...we need to see a picture of the gauge and what you are working with.
Old Aug 19, 2009 | 06:20 PM
343whpDelSol*'s Avatar
heres the pictures guys..sorry about them bein not centered and shit...i was just shooting in the dark outside..but i think youll get the idea of what i got goin on:
98 Eddie Bauer Explorer with single 12W7: 7th loudest vehicle in PA: Sold
93 Gutted Greddy Turbo and Zex Nitrous EG Hatch: Sold
07 Caliber with 13W7 and 20's: Traded
08 Ridgeline with all JL system: Traded
94 343whp D16z6 Del Sol: Sold
04 VW R32: Doin' Thangz
Old Aug 19, 2009 | 08:54 PM
mtber's Avatar
Instructions & wiring diagrams can be found on aempower.com
Old Aug 19, 2009 | 11:16 PM
DC Crew Member #1
Yup that is a true wideband gauge. Mtber is right about where to get the info.
Old Aug 20, 2009 | 04:48 AM
Blue92ludesi's Avatar
You have the correct gauge just figure out how to wire it, I can help you where do you stay at?
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Aug 20, 2009 | 11:02 AM
Like i said i've called AEM and gone on the instructions for wideband off of AEM's site. They both say their wideband has a 6 pin white clip and a 5 pin white clip in the back. A guy i work with also has one in his EVO, we pulled the gauge out and sure enough it was a 6 pin white and a 5 pin white in the back of the gauge. So AEM doesn't actually have a wiring diag. for this particular gauge for some reason. Atleast not that I can find under the wideband instructions on their site. But maybe someone can correct me on it
Old Aug 20, 2009 | 11:09 AM
  #17 (permalink)
DC Crew Member #1
If you didn't live so far away I'd help you wire it up...take a 9v battery and test the connections...you should have...1 ground, 1 power, 1 illumination, 1 signal, and probably a signal ground or something of that nature.
  #18 (permalink)
Thanks man...The gauge powers up like i said just isn't reading anything but 8.41 all the time....which AEM also said is weird because when a sensor malfunctions its usually at 14.7 from what they said
Old Aug 20, 2009 | 03:25 PM
  #19 (permalink)
FrodoGT's Avatar
Found the Vtec switch.
Originally Posted by custom240sx
No you can program an lc-1 wideband controller to output a wideband signal that is 0v=21 a/f and 1.1v=7.8 a/f
Narrow band gauges read from 0-1.1v...in essence that would mean I am using my narrowband to display a wideband signal...and believe me it DOES work.
This man doesnt know a damn thing. Yes technically that would make your gauge show an afr. But it is utterly USELESS for anything other than watching the numbers bounce back and forth, just like those stupid light shows. A narrowband o2 sensor is only even closely accurate at 14.7:1. Anywhere else and it cant be relied on any more than a politician.
TR Old Skool EF Crew #24
Old Aug 20, 2009 | 03:31 PM
  #20 (permalink)
FrodoGT's Avatar
Here you go.
http://www.aempower.com/images/produ...%2030-4100.pdf
The aem wideband uses a proprietary connector to join the sensor with the gauge. Its like a locking clip latch that secures the plug. Then the gauge itself has a group of wires for power, ground, and an output. There is no illumination wire as the gauge has a small photosensor in the face that auto-dims the gauge at night.
I would know this, I have one in my car right now, I installed and wired it myself, and it reads properly with a 0-5v WIDEBAND input and output feeding into my S300. Buying an lc1 controller and rigging up a narrowband to it is literally the most ghetto attempt to attain performance out of a car ive ever seen, and Ive seen charge pipes made from brake cleaner cans...
