can i run turbo on stock b17a1??????
Old Feb 24, 2002 | 08:27 PM
lostandconfused's Avatar
i have a 91 hatch with a b17a1 all the bolt ons including aem cam gears and adjustable fuel pressure reg. I was wondering if i could runa turbo with low 8-10 lbs of boost with out having to pull my motor and do bottom end work. or would my motor blow up or detonate or something.
If You Can't Beat Them Join Them
"you'll be joining"
Old Feb 24, 2002 | 09:08 PM
99B16Si's Avatar
you can run a turbo on anything. i wouldnt reccommend 10lbs on an old stock motor though
Old Feb 26, 2002 | 09:42 PM
letsrollagn's Avatar
BRT OVERKILL
Get the motor rebuilt and sleeved and then boost till your heart is content or blow it up and buy a new motor...
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Old Feb 27, 2002 | 05:15 AM
Patrick's Avatar
Hang on Sloopy
Originally posted by "Someone"
Originally posted by hybridEG
8-10 is right in the ballpark for what p.s.i. you can run on a stock turbo kit. like the drag kits wastegates are set for 8 from drag so you should be ok. just make sure you do some perventive matience bfore you do the kit I.E. new bearings seals thicker head gasket will help also. Basicly a nice rebuild wich will cost you around 300-500 depending on where you get the parts from and how far you go.
are you just recommending the rebuild before the turbo because of the fact that its an older motor or would you suggest that under situation. I have a 98 teg ls that I may be turboing in the next month or so....thanks!
Patrick
Looking to get flooring done in your home or office? Carpet, Ceramic, Marble, Wood, Etc. Feel free to contact me via PM. Thanks!!
low4cyl
Dec 27, 2000 02:31 PM
2000SE
Nissan/Infiniti Tech
8
Oct 17, 2000 06:36 AM
FastFour
Sep 26, 2000 04:16 PM
Blood_Sun
Toyota/Lexus Tech
Jul 20, 2000 04:15 PM
TampaTraps
War Stories
4
Jul 2, 2000 10:54 AM
