Soch head desing
Old Feb 15, 2002 | 06:59 AM
civicextpa's Avatar
Between the D16z6 and the D16y8 which one has a better head desing?. What needs to be done in order to install and D16y8 on and D16z6 motor. Thanks for you help in advance.
Jorge
Old Feb 15, 2002 | 11:02 AM
civicextpa's Avatar
Thanks Rob
Old Feb 16, 2002 | 05:46 AM
GOTTI's Avatar
OEM Parts Specialist
Originally posted by "Someone"
Originally posted by Robster
y8 has a better cam .2 higher compression better intake mani better combustion chamber design. To put it on your block it bolts right on if you use the y8 gasket with that head youll end up with 9.6:1. Youll have to use your distributor. It doesnt bolt right up. Youll have to cut one of your distributor legs to get it on there which isnt a problem distributor will still work just fine. Use your current inejectors. Everything else plugs right in youll have to cap off one vacumn nozzle on the intake manifold turn the throttle bracket upside down or else your current cable wont work. There isnt a place to mount your EVAP so youll just have to zip tie it to the firewall its not a big deal youll need to mount your intake air temp sensor onto your intake pipe or you can drill 3 holes in the y8 manifold and it will go in. Getting the head on is the easy part the using that manifold causes you to need to do a lot of little things that I just mentioned. Use your z6 throttle body and sensors. Use the y8 fuel rail on the y8 manifold.
man i thought it was easier than that...ouch..i dont like the idea of cutting the distributor and stuff...hmm...
do you think its really worth it?? i havent heard anyone say it is.
Old Feb 17, 2002 | 06:00 PM
GOTTI's Avatar
cool..well let me know when you do it..i want to see the difference...i havent had a new civic beat me yet with a SOHC so....i think ill stick with mine for now
Garrett
Mar 13, 2001 12:50 PM
hybridEG
Mar 8, 2001 04:30 PM
sy2173
Nissan/Infiniti Tech
10
Feb 21, 2001 02:32 PM
redinjuns
Dec 12, 2000 09:25 PM
16gAWD
Nov 29, 2000 05:22 PM
