crvtec or ls/vtec?
Old Feb 8, 2002 | 08:53 PM
chet's Avatar
All Aboard
im probably going one way or the other...and maybe turbo after that. currently im running a stock b16a3 and its just not fast enough. which setup is better? i have a 1993 del sol si...swapped in the b16 a few months ago.
www.hondaswap.com
thanks chet.
Old Feb 8, 2002 | 09:10 PM
88EFSiR1J1's Avatar
go with the B20 both the B20 and the LS are going to need that slight modification to run the VTEC head so why take advantage of the extra torque from the B20.
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old Feb 9, 2002 | 09:20 AM
onelove's Avatar
Team Titan
B20 is the setup. I have a friend running the 1.7 crank in his with endyn rollerwaves. The motor is built NA and make 210 and 141 with the flatest torque curve I have ever seen. All this with only 18** cc of displacement.
Old Feb 9, 2002 | 04:19 PM
cyanide's Avatar
yeah the b17a crank makes a good torque curve with the b20. you should also think about the r/s ratio the b17 should help it a bit.
99hatch-clint
Feb 20, 2001 10:29 AM
hybridEG
Feb 12, 2001 09:23 AM
90teggs
Feb 5, 2001 04:04 PM
hybridEG
Jan 29, 2001 11:37 PM
