Tranny leaking and clutch wet?
Old May 6, 2009 | 07:14 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
Default Tranny leaking and clutch wet?
So my friend seems to think his LS tranny is leaking onto his clutch and making it slip. As far as I know there is no seal where the Main shaft is, so is he wrong and his clutch is just going or is this a probability?
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old May 6, 2009 | 07:18 PM
Mr. Stealyogirl
BTW the 2 bolts for the rear mount are fucked up, and barely thread on, so could it not be pulling it flat enough with the block to seal it? Shed some light please guys were stumped.
www.jdmmindz.com
Old May 6, 2009 | 07:44 PM
joe'scrx's Avatar
the main seal behind the flywheel could be leakin
Old May 6, 2009 | 08:13 PM
Mr. Stealyogirl
Thats the only thing that sounds plausable but its fine.
www.jdmmindz.com
Old May 7, 2009 | 03:41 AM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
one way to find out.. get under the car take the flywheel cover off and check for oil residues... if its slipping that noticeable then there most be oil in there..
Old May 7, 2009 | 04:57 AM
JoKiE crx4294's Avatar
popeye built!
the only way oil would get in there is the front main seal. Whoever put the new one in probably knicked up the front main seal housing.
Can't spell strength without tren
AAS...It's whats for dinner
Old May 7, 2009 | 05:02 AM
KJ's Avatar
KJ
bored at work
Could also be a hairline crack in the tranny casing. This happened to a friend of mine with only 350whp or so and alot of hard launches. Tranny can leak from where the input shaft comes out of the bell housing. I've replaced those seals on BMW trannies but have never needed to on a Honda, but I'm sure it is possible.
Old May 7, 2009 | 05:05 AM
lzylst's Avatar
Rear main seal or input shaft seal.
Vance @ 863-604-2139 for any questions
Old May 7, 2009 | 06:39 AM
Derka's Avatar
TR Balla Donor Supreme
ive had a leaking input shaft seal on one of my civics, caused my clutch to slip, in a stock sohc
1998 crv daily beater
Old May 7, 2009 | 06:59 AM
popeye built!
I was gona say cracked casing, but you usually only see that on high whp cars. Iv never seen it leak from the input shaft seal.
