Tranny leaking and clutch wet?
It could be the rear main seal or input shaft as stated. Also the two rear bolts for the mount do not hold the tranny to the engine. Just to the mount. Even if it did make bad contact the transmission is a separate independent unit and does not need to be attached to the car to hold oil.
TR Old Skool EF Crew #24
