suspension question????
Old May 7, 2009 | 03:12 AM
RKTcivicEF's Avatar
hhhhyyyyeeeeeaaaaa son!!!
Default suspension question????
I have a 93 DA and was wondering, would i be able to use EF forks for my suspension? I have function and form full coilovers and i raised the spring up and dropped them all the way down but its still sits to high. I was thinkin maybe the EF forks were shorter or something. Any help is appreciated.
R.I.P Ryan J Sneddon aka skinny 6.25.1982-5.19.2007
TR "Old Skool DA" Member #68
Old May 8, 2009 | 08:55 AM
Default When Your Car Sits Too High I Can Fix It
When your car sits too high I can fix it........for most cars....I will have to see it first....there are about 6 kinds of springs, and some things depend on the suspension design.
If the hole in the top of the fork is the same size where the shock fits into it, then the forks may interchange. Check also the distance horizontally
where the long bolt goes through.
With some cars, the shock and spring combination varies in height, even if the forks are the same, and with some cars, I can modify that also.
If you want someone to look at it. I will do that.-No charge.-Bob
