K20 piston question
Old 04-26-2009, 04:56 PM
DC Crew Member #1
custom240sx's Avatar
Default K20 piston question
Can stock k20 pistons fit on LS rods? If they can what compression ratio would they yield?
I was thinking of putting k20 pistons on LS rods in a b20 as a cheap way to up compression but I am assuming that it can't be done.
Old 04-26-2009, 05:09 PM
MUSTANG NAZI!
mighty_mouse12's Avatar
Dont Think It Can Be Done, I Have Heard Of K Pistons On F Rods? But Never B Series
OLD SCHOOL EF CREW MEMBER #100
Old 04-26-2009, 05:10 PM
-Proud Croatian-
92 CiviC H/B's Avatar
^ I'm with that.
.TR's OldSkool DA Crew Member #14.
Old 04-26-2009, 06:29 PM
DC Crew Member #1
Anyone else with input? I did some research and couldn't find anything. Thanks to those who replied too.
Old 04-26-2009, 06:35 PM
love hondas ftw
vonrobins's Avatar
no the answer is no , and your damn sure not gonna fit k pistons in a b20 block - deck height is different k is 86mm b20 is 84 there would be alot of custom work needed for u to even think about building a 86 mm b series
._________________________
Old 04-26-2009, 06:37 PM
DC Crew Member #1
Thank you sir...that was what I was looking for. I hope you know your stuff because I am taking your word for it. Rep given.
Old 04-27-2009, 09:02 PM
civicized's Avatar
Deck height isn't a factor - that has to do with the K20 block, not the piston. The compression height of a k20 and a b series piston like p30 is the same at 1.181. The issue is the pin size. K20s use a .860 pin, while the LS/B series has a .827 pin.
Old 04-27-2009, 10:42 PM
starting over
sleepinsol's Avatar
i thought the k series block was 87x87 mm. i know its square bore. either way you would need a ton of sleeve work to make the bore useable, a really good head gasket to seal the thing, and like nick said, u would have to find a way to make the pin work. perhaps a set of custom rods. your best bet is the rs machine itr copy piston that they make for b20s.
Old 04-27-2009, 10:57 PM
TR Balla Donor Supreme
poorboy44's Avatar
k20= 86x86
k24= 87x99
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old 05-02-2009, 10:10 PM
Chronik Fab's Avatar
fyi f20 is 11:1
