Tapping in the engine!!!
Old Apr 16, 2009 | 01:37 PM
  #41 (permalink)
azkoopa's Avatar
its a stuck lifter i had the same problem about 4 months ago with my rebuild but i pulled the head completely apart to find out
Old Apr 16, 2009 | 02:12 PM
  #42 (permalink)
Gidget's Avatar
I've gone Euro
^^ Mine DOES sputter from time to time... I was planning on putting in a new fuel pump this weekend...I thought that might be the problem.
1973 VW 412 wagon type IV
1986 VW Golf GTI
2001 Jetta Wolfsburg 1.8t stage II on BagYards (the daily)
EJ Crew Member #9
Official TR 5th Gen Civic CREW member # 38
Old Apr 16, 2009 | 02:14 PM
  #43 (permalink)
Gidget's Avatar
I've gone Euro
And now I'm getting a little confused. In the first post you said "tap" AND "knock" ... but they're different sounds. Which one is it? Tapping can be lifters which is common Hondas. Knocking can be tons of different things.
I was under the impression is was more of a knock you're hearing
1986 VW Golf GTI
EJ Crew Member #9
Old Apr 16, 2009 | 02:51 PM
  #44 (permalink)
CrXSibeast's Avatar
its a tapping sound from the head which i probably bend one of my valves, bc i over rev'd
TR "Old Skool DA" Member #39 Crew
Old Apr 16, 2009 | 02:55 PM
  #45 (permalink)
rangcrx's Avatar
engine building &best
so you over reved on crank that has already had a spun bearing and was not checked?i am guessing there will be more problems to this motor
i love AUTOZONE
Old Apr 16, 2009 | 02:58 PM
  #46 (permalink)
rangcrx's Avatar
im sure you did not bend a valve,you would drop a valve first from over reving the motor..other wise the car would pretty much be undriveable
i love AUTOZONE
Old Apr 16, 2009 | 03:02 PM
  #47 (permalink)
Gidget's Avatar
I've gone Euro
plus wouldn't a bent valve have some other symptoms? Backfiring alot? Smoke?
1986 VW Golf GTI
EJ Crew Member #9
Old Apr 16, 2009 | 05:02 PM
  #48 (permalink)
CrXSibeast's Avatar
no she doesnt backfire or smoke just tapping sound and no power at all
Old Apr 16, 2009 | 06:34 PM
  #49 (permalink)
nenedelmambo1's Avatar
exactly how mine feels!!
but the motor has never spun a bearing and idk what it takes to spin a bearing lol
Old Apr 20, 2009 | 12:16 PM
  #50 (permalink)
pressuredsol's Avatar
Pleasure the do me
i have a tapping sound in my lsvtec setup as well, had valves adjusted and still doing it, i believe its the lma's or a stuck lifter or something in the head also. Need to make a video and post it to get some advice, couple people heard it and all say probably the rocker system. IDK?? B18-b bottom end and B17 vtec Head.
