type r timing
Old Jan 9, 2002 | 10:04 AM
KJ's Avatar
KJ
bored at work
Originally posted by "Someone"
Originally posted by 93sircivic
I think if you got the obd1 to obd2 ecu adapter harness then It would be fine but I have never heard of it being done. Therefore you would have an obd1 ecu reading an obd1 engine harness and sensors and the car wiring between the ecu and the engine harness being the only thing obd2.
The car will probably run the p72 ecu regardless. I know I can use the dx harness and add the wires as necessary but I want to know if I can use the obd1 harness so I dont have to switch to a obd2 distributor and oil pump and also rewire the injectors. Just curious.
Old Jan 9, 2002 | 08:12 PM
93sircivic's Avatar
Well if the your p72 ecu is obd 2 then you will have to have those sensors on the dist. and the crank angle sensor wired in. Use the injectors that match up to the harness you use.
obd1 ecu+obd2 dist=ok
obd2 ecu+obd1 dist.=not ok
hybridEG
Mar 8, 2001 04:30 PM
sihatch
Feb 3, 2001 09:19 AM
hybridEG
Jan 30, 2001 06:23 AM
rockin rocco
VW/Audi/Porsche Tech
Jan 26, 2001 09:35 AM
