darn timing belt
Old Jan 25, 2001 | 06:14 PM
rockin rocco's Avatar
i have a problem yesterday when i was installing a new timing belt tensioner. i belive the belt slipped a to0th does anyone know what the symptoms of retarded or advanced cam timing would be ???
j-zin 84 vw scirocco
everyone talks about there torque peak well......i talk about my torque plateau!
PARKIN AS HARD AS I CAN!
give me boost!
Old Jan 25, 2001 | 10:45 PM
well if it skipped to many you would run ruff as hell so ruff that you more than likely wouldnt be able to keep the car running happened to a buddy of mine
teal 94 integra gsr 99 saw blades aem intake &cam gears. moderating since sep. 2000
skunk 2 coilovers
give me boost!
Old Jan 26, 2001 | 05:16 AM
GTIXpress's Avatar
VW Guru
Poor running engine detonation poor fuel mileage. And depending on the engine and how many teeth it slipped you could end up with bent valves. I dont think VWs are designed that way though.
Joe
Joe P.
2002 VW GTI 337
1969 VW Type III Squareback
www.vdubnut.com
Old Jan 26, 2001 | 09:35 AM
well its running ok the fuel mileage is i guess a little higher at idle its rough but it idles fine driveability is better and its smo0ther up in the rpm range so i cant be far off im gonna try adjusting the timing and seeing if that helps the only real problem in having is a loss of power its not its normal balzy self and im pissed thanks guys!
give me boost!
