problem with air fuel ratio gauge, gauge savvy people help!
Old Mar 23, 2009 | 05:30 PM
SloCivic's Avatar
Default problem with air fuel ratio gauge, gauge savvy people help!
hey, i have a 1994 civic ex and i was trying to install a a/f ratio gauge.
and have a question.........
for the a/f gauge there are 4 wires,
one for the
- battery
-one that taps into the headlight
-one for the fuse box
- and finally the ecu
i have 3/4 in working order/ hooked up, i know i have the three hooked up right because when i turn the car on, the gauge gets power, but the lights are staying on the "rich" side and not moving @ all, i know it is because of the one wire that i have not configured yet . it says in the instructions to tap the wire in to the ecu, where do i tap it in to on the ecu? do i splice a wire and tap it or are their ones i should avoid?
im sorry but this is hard to explain....
any help would be appreciated.
Old Mar 23, 2009 | 05:34 PM
YARO's Avatar
Smith & Wesson Protected.
Is it a wideband or just a christmas light that bounces up and down for no reason?
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Mar 23, 2009 | 05:40 PM
SloCivic's Avatar
lol a wideband
Old Mar 23, 2009 | 05:44 PM
YARO's Avatar
what kind?
Old Mar 23, 2009 | 05:50 PM
SloCivic's Avatar
wait, sorry to be confusing, i just asked my friend and told me he was pretty sure it was a wideband, i did some quick research and found out it is not.
well i don't think so,
i got it for free it is a sunpro style line ? something like that.
Old Mar 23, 2009 | 05:52 PM
YARO's Avatar
well LMAO those things are pointless
Old Mar 23, 2009 | 05:55 PM
HonkeyDong's Avatar
Every dog has his day.
yeah narrowband A/F gauges are pretty much useless. Only purpose they serve is to let you know your O2 is working.
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Mar 23, 2009 | 05:57 PM
SloCivic's Avatar
ok i guess, well i have it might as well put it in.
so do i splice the wire that is supposed to go into the ecu into the o2 sensor?
Old Mar 23, 2009 | 05:59 PM
tai mishuu911's Avatar
rut roh
youre missing a ground. should be black?
the one that runs to the headlights only serves the purpose of dimming the gauge at night. if you dont want them to dim you can just ground that out too for maximum brightness.
the one that goes to the ecu taps into the 02 sensor line. i forget the color. phearable has a pinout i believe in their tech section on their site
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Mar 23, 2009 | 06:05 PM
SloCivic's Avatar
thanks alot!
ya sorry forgot to mention the ground, but ya i want it to be as bright as possible so i will just undo the headlight wire.
tomorrow after work i will finish and post pics, if i run into any problems i know who to ask/
arnt you the kid who comes to the parkside meet sometimes?
