CEL on but doesnt throw a code
Old Feb 20, 2009 | 08:34 AM
SLOWIMPORT's Avatar
pshhhhhh bahbahbahbahbah
Default CEL on but doesnt throw a code
i got a po6 chipped from Phearable its chipped for y8 basemap and vtec i wired up all the vtec wires to it and now when i get on it the CEL comes on and stayes on untill i shut it off then try to get the code and it doesnt say its throwing a code.
any ideas of what it could be??
TR "FIT" Member #001
Old Feb 20, 2009 | 09:52 AM
JoKiE crx4294's Avatar
popeye built!
ecu is bad possibly, mine does the samething.
Can't spell strength without tren
AAS...It's whats for dinner
Old Feb 20, 2009 | 11:11 AM
Jap's Avatar
Jap
VTEC Out
When you turn the key to KOEO (Key on engine off) does the CEL go off then turn on once the car is running or stay on the entire time ?
Check the ECU fuse in the fusebox and then go from there
Hondata saves lives
Old Feb 20, 2009 | 12:43 PM
SLOWIMPORT's Avatar
i just drove it again the CEL light comes on at 5200 thats what vtec is set at but it stays on the whole time i drive the car untill i shut it off the car
and yeah the cel stays off till i hit 5200 then it stays on..
the car drives normal the whole time
Old Feb 23, 2009 | 08:47 AM
Nandosol's Avatar
Garage Slut
Sounds like a problem with your vtec wiring/ground. or your ecu is fried.
Old Feb 23, 2009 | 10:44 AM
Jap's Avatar
Jap
VTEC Out
VTEC Spool solenoid code more than likely
Hondata saves lives
Old Feb 23, 2009 | 10:58 AM
Nandosol's Avatar
Garage Slut
Thats what I was thinking too, but it would still read once you checked the codes.
Old Feb 23, 2009 | 12:47 PM
SLOWIMPORT's Avatar
so you think i should change my vtec solenoid??
Old Feb 23, 2009 | 12:52 PM
Nandosol's Avatar
Garage Slut
Check your wiring. Do you have a multimeter?
Old Feb 23, 2009 | 02:50 PM
SLOWIMPORT's Avatar
yeah i have one what wiring should i check??
