CR-VTEC
Old Dec 12, 2001 | 10:47 PM
  #31 (permalink)
BIG_Truck_Driver's Avatar
Wherever I may roam...
Originally posted by "Someone"
Originally posted by webdog
860 - pistons rods
250 - skunk2 p28 ecu
What compression ratio are you going to run with those pistons?
If its anything halfway decent you should junk that skunk2 ecu for something programmable.
The ignition curves in the skunk2 ecu are quite advanced and will cause serious detonation if you are running high compression.
Old Dec 13, 2001 | 09:46 AM
  #32 (permalink)
webdog's Avatar
good call... and w/out a knock sensor or a J&S detonation is something i def dont want
Old Dec 13, 2001 | 11:13 PM
  #35 (permalink)
Originally posted by rainmanEK
the skunk ecu runs rich! it would decreas the chanc of detonation with more fuel!! i have had no probs with my skunk other then ideling?
Yes it runs rich but that is not the only factor in detonation.
the timing curve is too asvanced if you run high compression.
If you dont mind me asking what compression ratio are you running?
Old Dec 14, 2001 | 01:30 PM
  #39 (permalink)
letsrollagn's Avatar
BRT OVERKILL
ITR internals(pistons rods...hahahaha...no)....maybe in the head but definitely not the block they meant oil pump/etc... b20s are not starter motors and yes as mentioned above there is no painless swap unless you pay someone else to build it there is always going to be some odds and ends.....go b16/b18 think about crvtec later but you are on the right track....
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Old Dec 14, 2001 | 02:10 PM
  #40 (permalink)
webdog's Avatar
Im running 12:1 compression. Cant I use my apex VTEC controller to make up for the timing and fuel shortcomings in the skunk2 ecu?
