need help trouble shootin ls vtec oil leak
Old Feb 3, 2009 | 03:42 AM
  #21 (permalink)
96ek's Avatar
Originally Posted by rangcrx
you honed the block yourself theres your problem,your going to have to take it to a machine shop thats your oil leak i bet it smokes right from start up.thos Self honeing hoook to a drill blocks dont work.
Umm..yes they do work you just dont know how to use one.Glad you got it OP.
Old Feb 8, 2009 | 06:24 AM
  #22 (permalink)
MightyMaxGS-T's Avatar
ehhh im with rang on this one, ive used both the the ball hone and the spring hone when i have been too broke to go to the machine shop, it gives so-so results and its not really consistant. rang has a lot of experience and im pretty sure he can use a hone, its not that hard. hone a block urself, then bring it to a machine shop and see which one has a better finish. if you tell me they are the same you are a liar or blind.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Aug 28, 2009 | 05:36 PM
  #23 (permalink)
nitrous-addict's Avatar
im not big on hondas but some piston rings are cut at an angle if you put them upsidedown it cold cause that also not lining your oil rings properly
Old Aug 28, 2009 | 06:08 PM
  #24 (permalink)
Paulino's Avatar
Not harsh, just truthful
Wow way to grave dig a thread from february..he doesn't even have car anymore, it was stolen,stripped, recovered now the op owns it..
Old Aug 28, 2009 | 07:44 PM
  #25 (permalink)
Old Renegade's Avatar
Cool Runnings
not a good way to make his first post...much more saying he is not big on hondas but making comments on a honda forum.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
