need help trouble shootin ls vtec oil leak
Old Feb 1, 2009 | 07:08 PM
civicized's Avatar
You said you just built the motor. Did it get bored, honed, new rings? Was all measured to spec for clearances, etc?
Old Feb 1, 2009 | 07:31 PM
JoKiE crx4294's Avatar
popeye built!
probably bad valve guides. Also need to get a valve job after installing new valve guides.
Can't spell strength without tren
AAS...It's whats for dinner
Old Feb 1, 2009 | 07:36 PM
luvsracin87's Avatar
turbo hhhmmmm?
Yes freshly built. I honed the block, it has new roc racing rings, has new honda bearings. I'm putting new rings on that piston tomarrow. And if it is still smokin I'm going to put a ls head on it to see if the gsr head is cracked or somethingto that extent
Steve: (813) 810.4146 <~ call or text
Old Feb 1, 2009 | 07:42 PM
turbo hhhmmmm?
when I had the head resurfaced I had national cylinder head do a 3 angle valve job and check for loose valves guides, and they installed the felpro valve guide seals
Old Feb 2, 2009 | 02:38 AM
rangcrx's Avatar
engine building &amp;amp;amp;best
you honed the block yourself theres your problem,your going to have to take it to a machine shop thats your oil leak i bet it smokes right from start up.thos Self honeing hoook to a drill blocks dont work.
i love AUTOZONE
Old Feb 2, 2009 | 07:37 AM
turbo hhhmmmm?
^ I will ook into that today
Old Feb 2, 2009 | 06:02 PM
  #17 (permalink)
turbo hhhmmmm?
ok i found the problem. i pulled the piston out and i guess the person who pressed the piston on smashed the piston alittle and had the oil ring pinched. i should have payed a little more attention when i put ths rings on so i got some sand paper and took out the pinch. and i put new oil ring on. thanks to all who replyed
Old Feb 2, 2009 | 06:18 PM
  #18 (permalink)
rangcrx's Avatar
are you sure there are not SMALL or tiny pits in the cyl wall that will make you burn oil while driving
i love AUTOZONE
Old Feb 2, 2009 | 07:15 PM
  #19 (permalink)
turbo hhhmmmm?
The cylinder walls seemed pretty smooth, I couldn't feel any thing with my finger nail, so ill have a better idea tommarow in the sun. But from just driving it home and to the store I tellit wasn't burning oil. And when I pulled the plug it looked dry, not like a pool of oil like before
Old Feb 2, 2009 | 08:28 PM
  #20 (permalink)
tegSPEED813's Avatar
Unregistered User
zero gravity WTF!
TR "F#CK Thieves" crew member #1
