SOHC or DOHC
Old Feb 1, 2009 | 07:03 PM
  #21 (permalink)
StrictlyBusiness's Avatar
Mr. Stealyogirl
Originally Posted by SPJosh
going SOHC thx all
Have fun not making any power and especially TQ
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Feb 1, 2009 | 07:07 PM
  #22 (permalink)
K20aEK's Avatar
None...b series><go with k series..
Old Feb 1, 2009 | 07:28 PM
  #23 (permalink)
DD.'s Avatar
DD.
Administrator
Originally Posted by StrictlyBusiness
He was tuned by Alpha, and we both know you can make 300 on a stock b16
Yes, that we do know. But, you can make well over 300whp with a built SOHC if you want to. Alpha just tuned conservatively.
Old Feb 1, 2009 | 07:32 PM
  #24 (permalink)
Mr. Stealyogirl
It was like 17lbs pump gas.
www.jdmmindz.com
Old Feb 1, 2009 | 10:49 PM
  #25 (permalink)
KOMEMIERDA787's Avatar
go b 16 turbo lookYouTube - EK HATCH TURBO FROM ILLEGAL REVZ CREW
Old Feb 1, 2009 | 11:27 PM
  #26 (permalink)
FrodoGT's Avatar
Found the Vtec switch.
A Sohc will get plenty over 300 AND will make torque. They have a longer stroke (90mm vs 77) and the same disp. It will make more torque down low. Dont under estimate the sohc.
Also if your looking for 250whp a set of vitara pistons and forged rods will do that for less than 500 bucks. Id like to see you build the internals of a b16 for that. Straight From FJT you can get a complete rebuild kit including all the seals and belts water pump pistons, rings etc, and then rods for a total of 589. HA!
With that plus a cam some head work and an IM your ready for 350.
TR Old Skool EF Crew #24
Old Feb 3, 2009 | 11:49 AM
  #27 (permalink)
SPJosh's Avatar
your talking about a boosted d16 with vitara pistons and rods will make 250 right? not just the pistons and rods? also thx for making me feel better about my choice on SOHC lol
Old Feb 3, 2009 | 02:10 PM
  #28 (permalink)
Mr. Stealyogirl
Why? You can do that with a BONE STOCK b16, no need to build it. Also, to make that on the SOHC I bet you have to run a high amount of boost as well, but I have personally seen over 300whp on 9lbs of boost without problems on a conservative tune on a bone stock b16 w/ ebay kit.
DOHC>SOHC all dayyyyyyyyy
www.jdmmindz.com
Old Feb 3, 2009 | 03:02 PM
  #29 (permalink)
Codeine Fein's Avatar
ŁΘΘηεϒ ĝΘΘηź™
I dont see why this is still discussed. Im sure everyone has there preference, but be realistic. You will make more power off a DOHC then you will a SOHC. Id say, buy an b18a1 or b1. 9:2:1 compression and can handle some boost. all you need is Rod Bolts and Head Studs and your good to go. .02
RIP. Keith Wallace
Old Feb 3, 2009 | 03:11 PM
  #30 (permalink)
HonkeyDong's Avatar
Every dog has his day.
My friend is going to get his SOHC built and boosted setup tuned this friday by vega, I'll let you know how much it makes.
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
