Gsr, P30 Pistons, Type R Cams, Good Tune = Hp???
Old Jan 17, 2009 | 02:17 PM
  #21 (permalink)
rangcrx's Avatar
engine building &best
^sounds good,fine you dont have to bore the motor you can keep the motor in the car and rebuild it,BUt your not going to get what you want if you have you rmind set on what ou think will help you and what"respected"tr memebers tell you will work..but if your going to pay more then 1K for a nice build and its not aftermarket forged parts your wasting your money..if you would like a list of items i think you should go with and im sure mtber,Kj,and sleep can work with or change up i will be more then happy to post what i think you should do,and others can as well but only if you will take it in.we are trying to help you
i love AUTOZONE
Old Jan 17, 2009 | 03:58 PM
  #22 (permalink)
Skee's Avatar
toda b cams tear up stock belts says it on the site which belt is recommend for toda cams
ctr pistons, toda cams, crower valve train, call it aday lol
Custom high amp Alternators.. pm me
Old Jan 17, 2009 | 04:03 PM
  #23 (permalink)
rangcrx's Avatar
Oh wow i just read that he said "toga spec b cams on stock valve train but i hear they tear up timing belts" LoL wow!! but on that i would not use Ctr pistons in a 1.8 street car
i love AUTOZONE
Old Jan 17, 2009 | 04:15 PM
  #24 (permalink)
Skee's Avatar
the b's would destroy stock valvetrain at idle lol
Old Jan 17, 2009 | 05:40 PM
  #25 (permalink)
streetracingturbo's Avatar
ok so i know now that i don't know anything, the other machanic i talk to sold me on the port and polish and he can tune it there him self with crome- save me some cash ( i will get it dynoed when i get the exhaust and intake manifolds i like plus a new throttle body) i 'm getting the stock rebuild with p30 pistons
now i have decided to get a valve train and cams.
with just the rebuild, the port and polish and p30 pistons i should gain 15-20 hp i hope with a good tune i would like to gain an extra 15 hp from new valve train and cams
do they make a matching valve train and cam kit for like 800-1000 bucks
do they make a setup that will give me 15 hp
Old Jan 17, 2009 | 05:51 PM
  #26 (permalink)
rangcrx's Avatar
ok thats good on the pistons make sure you use arp rod bolts get rid of the stock ones the porting is still a waste of money you will not see any thing on that so that rebuild i hope is not more then around 450bucks i hope..but yes for valve train i would go with kms springsand Titanium retainers around 240
or the rev set around 260
then a nice buddyclub or skunk2 S2 cams 350 if you can find them here,or 450+new
BUt you can then sell your cams to make up some of that money
i love AUTOZONE
Old Jan 17, 2009 | 06:24 PM
  #27 (permalink)
i just noticed i can buy a new jackson racing supercharger for 2400 bucks
heres what i got for a quote, i'm just going to do the rebuild, p30 pistons and port and polish( he is going to port and polish the intake manifold and polish the throttle body and tune it with crome included with the build i'm going to get
so right now i'm at $1700
The Rebuild will include the following standard items: (options will be listed at the end)
*Removal and Installation
*Cylinder Block preperation /cleaning, honing, resurface all mating points
*New OEM bearings main and rod
*New OEM piston rings
*New OEM oil pump
*New OEM water pump
*New OEM Timing Belt
*New OEM T-Belt Tensioner
*All Gaskets and Seals OEM or Felpro Permatorque /customers discretion
*Basic Valve Job and clean cylinder head
*Clean Valve Cover or paint if needed
*New OEM oil filter
*4 Quarts Motor Oil
The price of a stock rebuild with OEM parts is $1200<-------::::::::
OPTIONS:
*Port and Polish Cyl Head / gasket match $300 w/ engine build<-------::::::::
*Polish Engine and Head and Clear $100
*New P30 Pistons shipped from Honda $200<--------:::::::::
*New CP 12.5/1 comp Forged pistons $399
*Cometic MLS Head Gasket $50
*ARP Head Studs $125
*ARP Rod Bolts $85
i getting the stuff with the arrow so far and i need to fine a valve train and cam set up to get me up to 30-35 hp with this build and i only want to spend around 800
Old Jan 17, 2009 | 07:20 PM
  #28 (permalink)
rangcrx's Avatar
engine building &amp;amp;amp;best
Originally Posted by streetracingturbo
If it was me
*Removal and Installation-150
*Cylinder Block preperation /cleaning, honing, resurface all mating points-40
*New OEM bearings main and rod-Acl 65"with polished crank"
*New OEM piston rings-Npr COME WITH PISTON
**NEW b16 pistons with rings-90
*New OEM oil pump-Obd2 used but inspected-45
*New OEM water pump-autozone-40
*New OEM Timing Belt-gatorback-30
*New OEM T-Belt Tensioner-no
*All Gaskets and Seals OEM or Felpro Permatorque /customers discretion-felpro 69$
*Basic Valve Job and clean cylinder head-unless your changing valves not needed
*Clean Valve Cover or paint if needed-5$
*New OEM oil filter-fram 2.47
*4 Quarts Motor Oil-15$
The price of a stock rebuild with OEM parts is $537-550 but thats just me
*Port and Polish Cyl Head / gasket match $300 w/ engine build --waste<-------:::::::
*Polish Engine and Head and Clear $100 -thats part of the cleaning above^
*ARP Rod Bolts $85
but thats just me
i love AUTOZONE
Old Jan 17, 2009 | 07:41 PM
  #29 (permalink)
rangcrx's Avatar
you do have a nice clutch set up right?like a 10lb flywheel and nice disc/pressure plate
i love AUTOZONE
Old Jan 17, 2009 | 07:42 PM
  #30 (permalink)
sleepinsol's Avatar
starting over
the rebuild and the pistons are good. 12:1 comp on the street IMO is a waste. youre not gonna make any more power than u would at say 11:1 comp. i would also say just use a honda head gasket instead of the cometic. its just as good. other than that make sure the cam u get is streetable. you dont need to rev to 10K to make power. other cams will make less peak power over a more broad rpm range than a larger cam, thus a faster street car.
