Block Guard Removal?
Im haveing a hard time removing my block guard anyone have any tips ive been sitting here for several hours and no luck and if it helps the block guard doesnt have any holes Thanks -Matt
EJ Crew Member #2
They're not really supposed to come back out. I've heard of the block warping and shit. Last one I tried to take out was nearly impossible. We had to drill it out in peices (if is not welded in there) they're no good If you're tring to sell it after.
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
dont take it out keep it in there
i love AUTOZONE
i love AUTOZONE
Thanks,
Carter
I have a car that poops little rabbits down the track!
here i remeber this came up b4
https://www.tamparacing.com/forums/h...ock-guard.html
i think this was one of my best thoughts
this is how you get it out,do it like you would open a egg
SMASH where the arrors are then it should fall right out
Shot with ViviCam 3705 at 2008-07-12
i love AUTOZONE
i love AUTOZONE
I dont see why i cant reuse it i bought it brand new put it in the block and put the motor in started the car like 3 times and took the motor out? so there said would i be able to use it again?
EJ Crew Member #2
the reason i say you cant remove it cause they are a bitch to get in there they are not made to be taken out,im guessing your not the one that put it in or you would know why you been sitting there many hours trying to get it out..they are made to fit very very tight on the deck to make the open deck to a m.i.d for less motion and make stronger...and if your able to take it out the block it was in will be off alot and need to be bored to make the cyl walls round again
i love AUTOZONE
i love AUTOZONE
