Similar problem as jdm punk!
Old Oct 28, 2008 | 04:19 PM
jdmdohcek98's Avatar
Originally Posted by AccordTypeR
why would you put gsr pistons in an LS, if its not a LS-V you need to put ls pistons and rings, you can usually get a full rebuild kit off ebay for about $250-300 and that includes evrything(pistons, rings,gaskets,water pump, timing belt,ect) thats what i would do just rebuild it, start out fresh
lol thats funny so only ls pistons can go in a ls block? i wouldnt recommend those ebay specials. all oem honda for me! i pm'ed you a price on the pistons and when you rebuild get the stuff from berto at autoway honda he is a good guy and gives a nice discount his ext is 128
Old Oct 28, 2008 | 04:20 PM
omni sells new map sensors check ebay
Old Oct 28, 2008 | 04:50 PM
AccordTypeR's Avatar
i didnt say that only LS pistons go in an LS block, i asked him why he was putting GSR pistons in a stock LS if hes not doing an LS-V, i would be careful doing that cause you can mess up the RS of your motor and make it unreliable, and if you build an LS-V the right way its fine
Old Oct 29, 2008 | 02:04 PM
how the hell would you mess up the rod stroke ratio of the block? he would be using the stock ls crank and rods. ls and gsr pistons are the same bore the gsr just has a little bit more dome which gives it more compression. and you dont need to do a ls/vtec to but higher compression pistons in your motor. please do some research before you misinform people.
Old Oct 29, 2008 | 07:31 PM
lzylst's Avatar
pistons have nothing to do with rod/stroke ratio.
I have a new omni power map sensor for sale if interested.
Vance @ 863-604-2139 for any questions
Old Oct 30, 2008 | 06:59 AM
ResurrectedLS's Avatar
On the block
lol okay guys is all good my friend has done it and his car runs like a champ..maybe if i would of said b16 piston now thats a diff story
This is what 18 holes smells like!
RIP Pablo 3rd Garcia will be miss By Millions 9/28/85-9/4/2007
TR "Old Skool EF" Member #147
Old Oct 30, 2008 | 07:48 AM
  #17 (permalink)
vonrobins's Avatar
love hondas ftw
you could use those to
._________________________
Old Oct 30, 2008 | 07:52 AM
  #18 (permalink)
vonrobins's Avatar
love hondas ftw
i have a lsvtec thats been running for 5 years now , just make sure wutever you do you do it rite
Old Oct 30, 2008 | 07:54 AM
  #19 (permalink)
vonrobins's Avatar
love hondas ftw
ressurrectedls,, did u come to brothers one day to change your exhaust off of pablos DA? idk i just think i remember your car from somewhere
Old Oct 30, 2008 | 07:59 AM
  #20 (permalink)
even b16 pistons will work as long as the bore is the same. just have be carefull with higher compression pistons with there dome and and piston/valve clearance but none of the stock oem piston would give you a problem
