k20a2 into ek question on mounts
Old Oct 27, 2008 | 06:36 AM
montriko's Avatar
______
Default k20a2 into ek question on mounts
k so i have been doin alot of research on what i want to do
and i want to noo if any body used hasport ekk1 mounts vs the ekk2 mounts and if there isreally a bigg difference
and also what about the innovative mounts
Old Oct 27, 2008 | 07:00 AM
ResurrectedLS's Avatar
On the block
Umm i think manny has something to tell us about.
This is what 18 holes smells like!
RIP Pablo 3rd Garcia will be miss By Millions 9/28/85-9/4/2007
TR "Old Skool EF" Member #147
Old Oct 27, 2008 | 07:15 AM
montriko's Avatar
______
shhh^^^
Old Oct 27, 2008 | 07:26 AM
k20tek's Avatar
the ekk2 are a better design and eliminate alignment issues
Old Oct 27, 2008 | 09:19 AM
jdmdohcek98's Avatar
+1 and with the ekk2 you can drop the car more with the k1 the oil pan gets dangerously close to the floor without being that droped and the angle on the axles is kinda scary too
Old Oct 27, 2008 | 12:46 PM
montriko's Avatar
______
ok so with ekk2 i woild need what from an eg??
Old Oct 27, 2008 | 01:07 PM
Ro.'s Avatar
Ro.
New Hasport EKK2 Mount Kit - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old Oct 27, 2008 | 01:44 PM
eg subframe
Old Oct 30, 2008 | 04:38 AM
Marc P's Avatar
K Power
Originally Posted by jdmdohcek98
eg subframe
Also need Control arms and front lower shock forks from a eg.
The Ekk2 has many advantages, with the motor sitting straighter(better for axles), has 2 mounting locations(so you can close the hood on a k24 swap), and lets you run a RBC manifold alot easier(motor sits back in engine bay)
If you decide to run EKK2, need to order drive shafts for EKK2 because they will be shorter than EKK1.
Hope this helps
Marc P
10.24@132/21700lbs NA Street Car
Old Oct 30, 2008 | 06:00 AM
kumar.'s Avatar
wrd.
o snap.
"Success is 99% failure" -Soichiro Honda
